Less weight = more power; Have you lightened your Z?
Originally Posted by dmoffitt
rick I just wanted to remind you how much I despise you. Every time I listen to my audio system, as much as I love it, I get a twinge of guilt and think "hmm, guttted carbon doors, Nascar bars and 800-1000lb springs aren't THAT far off of a street car, right?" - worst part is my girlfriend APPROVES?!?@?#!?@# DAMN IT AREN'T THEY SUPPOSED TO TALK US OUT OF THIS ****?!!
well, I've decided that I'm going to remove the rear speakers while I install the roll bar. Although I'm adding weight with the roll bar, I figure I should offset that somehow. Besides, I don't think those speakers even work. Have you guys tried setting the fader control to faze out the front speakers, and listen to the rear by themselves? They're practically useless!
Originally Posted by sentry65
rear speakers weigh nothing. You will save a grand total of 1 lb
I was really suprised at the weight of the speakers, dont weight anything. I thiought I would be shaving lots of weight by removing them but when I got them out I was disappointed to find that they weight almost nothing.
You all need to just by and AE86 Corolla
2000 lb with a full tank of gas
seriously though, it takes a lot to lighten the Z, it's a pretty heavy car from the factory. My list is similar to Ricks (not as extreme) as I still daily drive mine... but to all those considering weight reduction, DO IT! It's the best performance mod you can do!
my list (all #'s are approximate):
carbon hood -7lbs (cheapie hood, hacked out insides, now weighs ~8lbs)
drained w/w -5lbs
PC680 battery -22lbs
bucket seat -21lbs
no airbags -12lbs
tilton clutch/fw -48lbs
carbon doors -80lbs (w/stock inner door panel, no glass)
carbon hatch -54lbs (plexiglass window)
test pipes -20lbs
ti-exhaust -40lbs (single exit)
coilovers -8lbs
spare/tools -35lbs
pulleys -4lbs
Koyo Radiator +10lbs (extra coolant)
Cage +120lbs (full 8 pt. 2-5/8" DOM)
that puts me at about 220lbs less than stock... still over 3000lbs!
next possible things to remove:
p/s seat -21lbs
interior ~20lbs
a/c ~25lbs
heater core ~15lbs
starter ~5lbs
battery 13lbs
windshield ~20lbs (lexan)
front fenders ~3lbs (carbon)
stereo/navi ~15lbs
weather proofing ~8lbs
ABS system ~10lbs
e-brake ~2lbs
pwr/steering ~12lbs
intake manifold ~4lbs
beyond this, you start scraping for ounces... and then grams... etc.... gotta love the corolla
drained w/w -5lbs
bucket seat -21lbs
no airbags -12lbs
test pipes -20lbs
coilovers -8lbs
spare/tools -35lbs
pulleys -4lbs
p/s seat -21lbs
interior ~20lbs
a/c ~25lbs
heater core ~15lbs
starter ~5lbs
battery 13lbs
stereo/navi ~15lbs
ABS system ~10lbs
e-brake ~2lbs
pwr/steering ~12lbs
This spring I was at corner balanced @ 3170lbs with a Cdn touring 350Z (~ 3257 stock).
In terms of weight reduction, I had:
Track rims (7.5x4=~30)
Kumho MX rubber 245/40 all round (~ 10lbs)
JIC Coil overs (~10)
UR Flywheel (~10 at best)
Spare & tools removed (~ 30)
Y-pipe (~5)
UR main Pulley (~5)
Hotchkis sway bar +5
Avalon Harness bar +7.5
Additional affordable mods are:
Battery (-20) have one now.
Cats (-5x2)
Exhaust (-25)
Possibly hatch but I need strenght to mount my bike rack on it so it won't happen anytime soon. -35 with glass.
So without loosing daily driver comfort, the car can reasonably be brought down to: ~3100 lbs or just under. IMO, that's pretty good considering the luxury items and stiffness/safety our cars have.
Y-pipe (~5)
UR main Pulley (~5)
Cats (-5x2)
Exhaust (-25)
you can actually remove the ABS system? I thought that was mostly ECU stuff?
I didn't think the tilton clutch saved 48 lbs. Thought it was more like 30
The ABS pump, electronics, master cylinder, sensors, etc... will easily exceed 10lbs as confirmed by a few of the race teams who have gone with aftermarket brake systems.
have you weighed them? my stock clutch and flywheel are definetly not weighing 60 lbs. I mean I'll go weigh them if you like
Stock flywheel = 26lbs
stock clutch is about 20 lbs
tilton clutch/flywheel = 16 lbs
= 30 lbs of savings
I think you're adding in other transmission parts that are going to be there regardless of clutch or flywheel used
= 30 lbs of savings
= 30 lbs of savings
= 30 lbs of savings
http://performancenissanparts.com/ca...roducts_id=201
i don't know, my car is aug 02 build date
seems that no one is 100% sure on this. Some people say 56 lbs, others say 46 lbs - not just me
I took out the stock clutch out of my 03, and the clutch plate and clutch cover definitely do not weigh more than the flywheel, which is 26lbs. I'll have to weigh them to be sure, however.
Originally Posted by Nano
it's a 4 banger with insane whp potential for it's size(~400). Classic overbuilt older nissan engine
doesnt our vq have a higher hp potential then that?
The VQ has more potential with forced induction, but you end up getting even heavier... which goes against the whole point of weight reduction. You really can't offset weight by adding HP.
