Less weight = more power; Have you lightened your Z?
Originally posted by Blue Liquid
It looks like your car is on a lift kit, especially in the rear. Could this be a result of too much weight loss?
The problem with lightening for stock class is all the weight is off the rear of the car.
Originally posted by veilside350zTT
I figured the track model would be one of the litest. Since it doesnt come with leather seats and all that other ****. But its not how much more does the track weigh compared to the base???
From what I've researched, there is a lot of weight to be lost w/ the exhaust system. You can lose close to 80 lbs by replacing the cats, y-pipe, and b-pipe/exhaust with select other components.
Originally posted by Armitage
No leather, navi, etc... but it does comes w/ LSD, TCS, VDC, etc. A lot of other components that add extra weight. The lightweight rays help.
Yes, you can lose 80 pounds from the exhaust, but your "select" parts will have to be titanium.
GY-Z, I thought that as well, but it's been confirmed by a bunch of people who have done turbo installs say it's about 12-15.
BTW if you all didn't know
seibon now makes a CF hatch. it's only 550.00 shipped as far as i know.
i don't know the weight of the hatch, or if it's full CF or fiberglass lined with CF. (aka show hatch)
http://www.seibon.com/pdut_detail_pic2.asp?ItemID=325
Originally Posted by kernel
well they had mentioned a lexon replacement. but for daily drivers its just impractical
Can anyone get more info on this hatch w/ lexan?
Originally Posted by UsafaRice
A lot of weight for the track model comes from the brakes. People seem to forget this. IMO, having weight in the brake system is all right, because I'f rather have some heat capacity left when I'm slowing down from 130 than not. TCS and VDC are computer systems and do not add more than a negligible amount of weight.
Del105, why does your car look so high in the back?
If I decide to shuck some weight for the SCCA, I'm going to be weary of taking too much out of the back. Does anyone know how a manufacturer gauges weight distribution?
As much as I would like to change out the stock hood with a CF version, losing 50lbs. from the back of the car will only serve to make the weight distribution move to the front even more. I guess you'll have to come up with a way to reduce the weight off of the front. Has anyone come up with effective weight reduction methods for the front besides a light weight battery? Going to a CF hood won't save anything since the factory hood is pretty light already (unless we're talking dry carbon). Another thing to look into is lowering the engine to bring down the center of gravity. I know the Option Stream Z did this. Does anyone know how they managed to lower the engine position by 4cm?
-headers
-test pipes
-CF hood even if not dry can save 1-3 lbs (Every bit helps)
-Clutch and flywheel
-Removal of all unnecessary rubber and plastic in engine bay
-Remove windshield wipers for track
-Gutting interior with removal of sound deadener and foam that keeps heat from engine
Anyone else? I need to know too
There are a couple reasons it looks high in the back. 05 springs are stiffer and raise the back about a 1/2 in. over previous Z models. The other is that in that picture the rear of the car is not settled which is the main reason it looks so high. My car feels really good during auto-x very neutral with good turn-in. I hesitate to change anything at this point. I'm going to experiment with other shocks but at this point it is probably 90% perfect. Carter Thompson took 1st in my car at the national tour last weekend. I drove like crap but what I did learn is the car is fast the way it's setup.
Btw, I know you said the wheels and tires dropped a bunch of weight, but do you know exactly how much your Enkeis weight themselves? They are 17" right?
I was looking at the RP03s. I don't know how much they weigh though.
Sweet, 1st place... what kind of other cars was he competing against?
The competition was pretty mixed, rx8, M3, 350z ,MR2 turbo, 944 porsche.
The Enkeis with race tire weigh 40lbs front 41lbs rear.
Originally Posted by spf4000
It's good to lose the weight, but it's more important where the weight reduction comes from. If you can drop 80lbs by changing out the exhaust system, great, but it'd be even better if you can lose the 80lbs from higher in the car, like the roof, hatch, doors, etc. because that would lower your center of gravity. Losing weight from the bottom of the car could actually raise the center of gravity.
And so then you lower the car an inch with the Tein Flex system or your choice of suspension.
