Problem with Power/ loosing power
Old Feb 15, 2005 | 03:28 PM
Sonny350Z's Avatar
Sonny350Z
Default Problem with Power/ loosing power
text
Old Feb 15, 2005 | 03:50 PM
ReavTek's Avatar
ReavTek
The clicking noise is under a technical service bulletin Nissan put out. I believe the axle just needs to be re-lubed. If anyone has more info please post. As for the power loss... I dont really know what to say. Are you following the maintenance schedule? Are all the fluids filled? Maybe an ECU Reset would help: http://www.technosquareinc.com/350reset.htm
Old Feb 15, 2005 | 03:51 PM
Nano's Avatar
Nano
it takes some time to get to 250kmh, but 10km is too much. In 5th gear you should hit 230kmh in a breeze. after that it gets slower.
BTW last year on autobahn i reached 255kmh on digital display
Old Feb 15, 2005 | 10:17 PM
Sonny350Z's Avatar
Sonny350Z
text
Old Feb 15, 2005 | 10:32 PM
inanabhay's Avatar
inanabhay
wow - new engine after 2000km?
pls find out why and let us know
thanx
regards & good luck
Old Feb 16, 2005 | 01:37 AM
Sonny350Z's Avatar
Sonny350Z
text
Old Feb 16, 2005 | 04:49 AM
nuff's Avatar
nuff
Have you modified it in any way? Or is it bog stock? Could be sliping clutch, do you do a lot of hard launches and do you drive on your clutche a lot? does your car have VLSD? could this cause problems if it's broken? (I'm just throwing random ideas).
Old Feb 16, 2005 | 07:09 AM
Nano's Avatar
Nano
Originally posted by Sonny350Z
The german 350Z should run 263km/h on the digital display.
You sure?
All Z that I know are electronically limited to 250kmh. Europeans one included. In italy atleast they are limited to 250.
I tested mine with GPS, and at 253kmh on digital display, gps was at 252kmh. It would not go higher.
Old Feb 16, 2005 | 07:50 AM
juice79's Avatar
juice79
Try to reset the Drive by wire. That can be found on the Technosquare site as well
Uriyo_
Sep 8, 2021 08:46 AM
