NOS octane booster
Old Feb 18, 2005 | 01:34 PM
[]D[][]V[][]D's Avatar
[]D[][]V[][]D
Default NOS octane booster
It's sitting on my desk right as I'm typing this out now. I'm debating if I should put this in my fuel tank or not. It claims to raise octane levels up to 7 points.
Say if I do "experiment" with this additive, will this void my warranty?
What do you think guys?
Yay or nay?
Old Feb 18, 2005 | 01:45 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
It won't void your warranty.
Magnusson-Moss Warranty Act, look it up, it's against the law for the dealer to void your warranty before proving the modification caused the problem.
Old Feb 18, 2005 | 01:51 PM
[]D[][]V[][]D
Thanks for the quick reply nis.
So what's your verdict, should I try a can of this stuff in my tank?
Old Feb 18, 2005 | 02:01 PM
Brandon@Forged
Can't really help you there, I wouldn't think running a higher octane would hurt, but you might want to get some more opinions.
Old Feb 18, 2005 | 02:25 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
You'll be lucky if it raises it up 0.7 points.
Get some tolulene or xylene, or better yet, real race gas (vp racing 103, etc.)
Old Feb 18, 2005 | 02:29 PM
[]D[][]V[][]D
My friend just told me something like that. I'm reading the bottle and it says that it contains MMT/nitro methane.
Is it illegal to buy tolulene or xylene? I just found a gas station that has 100oct.
Old Feb 18, 2005 | 03:35 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Not illegal -- it's paint thinner. 10% mix will net you about +1-2 octane
I wouldn't go above a 10-20% mixture tho, and you're always better off with race gas from a station since it's properly lubricated with additives and also usually oxygenated for additional performance gains.
Generally higher octane will only get you better performance if you're knocking/pinging with your current gas (not uncommon with crap 91 in Ca). Your ECU will stop pulling out timing and you'll feel some gains. Tho IMO not worth it for the premium price you'll be paying -- the novelty will wear off very quickly after a few tanks.
Old Feb 18, 2005 | 03:58 PM
[]D[][]V[][]D
zx, thanks for the 411. I just found out that 100oct is nearly $6 a gallon. I don't think it would be worth my time and cash on a NA engine.
Thanks for your time.
Old Feb 18, 2005 | 04:19 PM
G3po's Avatar
G3po
Default octane
It is quite common to blend the 100 with pump.
Many with FI blend ~50/50 of 100/91 for an equivalent ~95.
However, as long as you still NA , it's not really necessary.
Old Feb 18, 2005 | 05:45 PM
DaytonaBlue04's Avatar
DaytonaBlue04
91 octane and 30% toluene will yield about 95 octane. For some real fun, add a little hydrazene.
Old Feb 18, 2005 | 09:34 PM
Kray Z's Avatar
Kray Z
Its against the law to have the 7 point formula thats intended for street use. If it is the 7 point its for off road use only. Not that anyone checks or cares but it is the law that the EPA put out there. The most on road octane boosters are 1-2 points.
My dyno friends that test the race engines on a daily basis found no benefit from the NOS brand.
Not that some won't work but if you only knew what was in that bottle you'd flip.
1-2 ounces of mmt 6-8 of inert solvents.
Its a marketing gimmik to make the bottle worth 8bucks
Im pro additive all the way. But just do some homework before believing what it says on the label.
By the way whats your Elevation? Are you N/a or FI
If your above 3000 feet higher octane does not help it actually can have an opposite effect.
for every 1000 feet of elevation you lose 6-10% of your engines air effieciency.
Bottom line is that lower octane fuels burn slower and take less heat too ignite thus you may have detonation if more air is available.
Higher octane fuels burn slower and take more air to ignite. if your up high you can create deposits from inadequte burning.
Air+ compression = heat.
IF your a FI it doesn't matter you need the higher octane cause your forcing more air in the cylinder than a NA.
Old Feb 18, 2005 | 10:41 PM
Sins4u33's Avatar
Sins4u33
just for future warning....down the road you should check your plugs when running octane booster....
Old Feb 19, 2005 | 06:18 AM
PhoenixINX's Avatar
PhoenixINX
You won't feel ANY difference.
Zero, zip, zilch... why bother?
Old Feb 19, 2005 | 06:57 AM
Z04's Avatar
Z04
snake oil. it won't do crap for performance but it will lessen the weight of your wallet
Importlife.com
Nitrous Oxide
Sep 8, 2003 09:56 PM
Chebosto
Aug 6, 2003 06:31 AM
Zaphod 350z
Nitrous Oxide
88
May 10, 2003 08:59 PM
turkish_eyebrow
Southern California
Mar 17, 2003 07:00 AM
