Help engine is running hot
Old Mar 28, 2005 | 06:16 PM
timdawg's Avatar
timdawg
Default Help engine is running hot
I just had the Blitz LM double row radiator, HKS Hi-powerexhaust, Kinteix test pipes, Crawford cast plenum, UR crank pully, & the Nismo thermostat installed. Now the engine temp gauge slowly starts to creep up to redline even when I am barely pushing down on the gas, but when stopped it begins to go down.
I was wondering if the crank pulley was slowing down the water pump so much that it can't keep up.
I was also wondering if I was running really lean, if that would cause temp to rise?
Any thoughts or suggestion would be extremely appriecated.
Old Mar 28, 2005 | 06:50 PM
Z CRUZN's Avatar
Z CRUZN
I seriously doubt that it's the UR pully - too many of them have been installed with no problems (including me & several friends). If I had to guess, I would point toward the radiator/thermostat install....did you bleed the air out of the cooling system after install & coolant refill? For the temp gauge to nearly hit redline, there's definitely something in the cooling system not right... Getting the air out of the system is a VERY important process that has to be completed when working on that system, be it hoses, thermostat, radiator, etc. The air bleeder valve for the system is near the firewall on the passenger side of the bay.
Old Mar 29, 2005 | 12:58 AM
jreiter's Avatar
jreiter
Some air left in the system is exactly what I was thinking, too. Definitely make sure you bleed that system completely. If that fails, try the stock thermostat again.
Old Mar 31, 2005 | 07:49 PM
alininger2001's Avatar
alininger2001
There is air in the hoses, you have to burp them.
Old Apr 1, 2005 | 03:06 AM
nitrous350's Avatar
nitrous350
Cause Befor I had a APS TT kit I used Kinteix plenum
I think small water hose connected to plenum and I had a leak on this hose
and Air in my cooling system and Tem. is going to red.....
Old Apr 1, 2005 | 03:20 AM
westpak's Avatar
westpak
SFZCC
Burp the system, just turn the plug and let air out until bubbles stop.
Old Apr 1, 2005 | 05:01 AM
timdawg's Avatar
timdawg
Thanks for all the help, I got it fixed last night. There was quite a bit of air in the lines, I had to put about 2 1/2 cups of coolant in. Then I went for an hour long drive and the needle never moved. Thanks again!
Old Apr 1, 2005 | 01:29 PM
Armitage's Avatar
Armitage
Good to hear thats all it was.
How's the car feel now with all those mods?
Fixxxercask
Nov 9, 2015 11:10 AM
