Royal purple question
Old Apr 2, 2005 | 06:38 PM
Andys'Z's Avatar
Andys'Z
Default Royal purple question
I am going with mobile1 synt engine oil.
Question is is it ok/enough, to use 5 quarts of (2 in differentail 3 in manual tranny) max gear royal purple GL5 80-90.
Old Apr 2, 2005 | 07:45 PM
ReavTek's Avatar
ReavTek
DO NOT Use GL-5 Lube. Your Transmission requires GL-4, using GL-5 can cause pre-mature wear and damage to the soft metals in the tranny. However, it is fine to use GL-5 in the Diff. I believe I used a little over 3 qts in the tranny of Redline MT-90 and I forgot what I used in the Diff but it was Redline also (I'll look it up if you want).
MT-90 Description from RedlineOil.com:
Popular in Nissan, Toyota and Mazda manual transmissions and transaxles as well as other selected applications, this is a 75W90 GL-4 Gear Oil thatÃÔ slightly heavier than MTL. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
I'd order 4 qts of this.
Old Apr 2, 2005 | 07:50 PM
NY 350Z's Avatar
NY 350Z
i used redline in my tranny also. Mobil1 in dif.
Old Apr 3, 2005 | 07:53 AM
lovetoclown's Avatar
lovetoclown
Royal Purple Max-Gear IS GL-4 Certified. Check their Web site. I used RP in my tranny and Diff. and had a noticable difference.
Old Apr 3, 2005 | 08:53 AM
Nano's Avatar
Nano
GL-4 and GL-5 are NOT formulation specifications, but performance specifications.
Most(especially in the past) GL-5 spec oil use additives that are corrosive to yellow metals. But that does not mean ALL GL-5 spec oils are corrosive to yellow metals.
Mobil1, royal purple and other oil manufacturers produce GL5 oils that are not corrosive to yellow metals.
Old Apr 3, 2005 | 09:39 AM
thawk408's Avatar
thawk408
Will nissan get pissed off and void your warrant if you use Redline fluids in the transmission? I heard this awhile back but was not sure if it was true.
Old Apr 3, 2005 | 10:42 AM
redline350ZZ's Avatar
redline350ZZ
Do you need to flush out your tranny????
If so with what kind of oil????
We have gear oil right????
All the places I called dont flush or wont put Redline/ Royal purple in....
Would would be the appropriate steps to replace tranny fluids???
Old Apr 3, 2005 | 10:49 AM
lovetoclown
You can change out the fluid yourself if no one else will do it. VERY easy.
Old Apr 3, 2005 | 11:22 AM
Andys'Z's Avatar
Andys'Z
Ok guys I dont really know anything about gear oils, so I didint get what you guysmeant with gl5 or 4, you your saying its ok to use maxgear gl5 in the tranny since its gl4 certified too?
What about if I wanted to go All mobile one, engine tranny and diff could I do that and if I could whats the gl..viscosity... name etc.. for it.
Old Apr 3, 2005 | 11:58 AM
redline350ZZ
Well i know that if you dont flush out the fluid you will still have about 50% left of what ever was in there in he first place so my real question.....
Is it bad to mix the stock NISSAN tranny oil and synthetic gear oil.....
Would it be better to flush out first then replace with whatever oil you want..... and if I should flush first what should I ask for at the shop that does the flush....??
Also what benefits will I experience...... I may have a synco issue right now in 2nd gear...will changing be better for my tranny / possibly fix issue???
Old Apr 5, 2005 | 09:11 PM
ReavTek's Avatar
ReavTek
I doubt it will repair any tranny issues you have now. My tranny is still hard to get into gear unless I double clutch on downshifts and/or rev match. It is much more notchy than it was when I first bought it. The oil does seem to coat better because when I do grind it the sound is much more muffled whereas b4 I could hear the tinny grind sound much more clearly. Overall, I am most likely going to swap out the oil for OEM fluid and try to get the tranny replaced under warranty... But, it is an uphill battle.
Old Apr 5, 2005 | 09:14 PM
redline350ZZ
What about the process for converting from STOCK to synthetic oil... what should I do....what have you all done???
Old Apr 5, 2005 | 09:29 PM
ReavTek's Avatar
ReavTek
Basically, I backed the car onto rhino ramps and jacked up the front to be more or less level. After that, you look for the transmission housing and you will see too flat bolts with a hex hole in them. One is on the bottom and one on the side. The one on the side is the fill hole, loosen it first. Then remove the drain hex bolt (I used an allen wrench) and the oil will drain. After it is fully drained you need either a suction gun or a funnel with a long plastic tube (put the funnel in the engine bay and route the tubing down into the fill hole) to fill the tranny. Repeat the process for differential. If you need pictures or what not I can try to take some tommorow. My AIM is AgentReaver if you have questions.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
