How much does the engine twist/torque under load?
Old Apr 15, 2005 | 10:14 AM
enhanced250's Avatar
enhanced250
Default How much does the engine twist/torque under load?
I have about a finger distance in between my heat shield and my hi flows (this is my thrid setup and still not happy). Some it his when i first start out (with the manual studder) and then again around 2 grand it is not rasp as all something is hitting
so i am wondering if that finger distance is enough space or the engine does twist that mush and ill have the remove the heat sheilds
thanks
Old Apr 15, 2005 | 10:48 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I can tell you that the VQ doesnt budge. The Greddy TT outlet actually has less than 2mm of clearance between the subframe member.
I've run the car on the dyno at 520whp+, and still see virtually no movment under load, or when I let off....almost looks like the engine isnt even running. I wouldnt worry.
Old Apr 15, 2005 | 11:06 AM
jeffw's Avatar
jeffw
I think someone that's NA had a problem with a lot of engine movement. Their theory was that one of the liquid filled motor mounts had ruptured. I think he bought the Stillen damper to hold the problem off until some good aftermarket motor mounts come out.
I don't have a thread link, but try searching for "stillen damper."
Jeff
Old Apr 15, 2005 | 08:28 PM
copba1t's Avatar
copba1t
I disagree. I had rubbing issues with my hi flows, and had about 1/4" of space that was being used up and then some from engine torque. I put on the Stillen Engine Dampener and the problem went away.
If you think you can tell just by looking at a running engine then you must have some highly calibrated eyes. The engine mounts on these cars are soft, and the engines will move around, at lease that is the case on my G35c.
Old Apr 15, 2005 | 09:12 PM
axxizzer's Avatar
axxizzer
Uh, I didnt know that the engine wasnt supposed to move...mine does, and it did before and after the pullies. Should I be scared? Should I contact Nissan?
Old Apr 15, 2005 | 10:11 PM
enhanced250
so cobalt you had a simmilair problem around 2 grand and up on heavey acceleration you can feel something hitting the floor boards and i HAVE the stock bracket on the cats so im thinking the whole eninge is moving and maybe jsut touching the heat sheilds
by taking off the heat sheild am my exposing another problem whats behind them anything that needs to be protected or will the hi flows let off less heat than stock?? please help because im sick and tired of swiching out pipes the sound is great but this rattling clunking noise is unreal
Old Apr 17, 2005 | 02:36 AM
jreiter's Avatar
jreiter
For what it's worth, my engine rocked like a baby's carriage when I would sit in the car and rev it hard. I installed the Stillen torque damper and that reduced it dramatically. Made a very noticeable improvement in driving feel.
Old Apr 17, 2005 | 07:49 PM
enhanced250
i figured out the probelm i had to bang out the floor board alittle bit and it fits perfect i never thought ultimate racing have fitment issues but i guess i was wrong
Old Apr 22, 2005 | 05:01 PM
copba1t's Avatar
copba1t
Yes this engine moves around quite a bit. I don't think it's a problem, for some reason that is beyond my knowledge the Nissan engineers used soft engine mounts, probably to reduce cabin noise or who knows why.
IMO the more the engine twists around, the more torque that is being wasted. I put on the engine dampener and the engine no longer moves around, so I am giving that wasted torque a new lease on life and hopefully a chance to get down to the wheels which is where I want it
Old Apr 23, 2005 | 10:58 AM
alininger2001's Avatar
alininger2001
I have heard that the g35 has less clearance and you have to bang on the floorbords a little to get them to fit. I beleive this is true for all aftermarket cats, they make them for the 350 and sell them to g35's, but they may not fit perfectly like on the 350.
Old Apr 23, 2005 | 07:15 PM
copba1t's Avatar
copba1t
This is true, I had to hammer the underbody of my G to fit the Helix cats.
Old Apr 24, 2005 | 05:17 PM
skyl1ne6mt's Avatar
skyl1ne6mt
wait, do you hammer the underbody or the heatshield?
Old Apr 24, 2005 | 08:35 PM
axxizzer's Avatar
axxizzer
wait, so GQ is totally wrong? That doesnt make much sense, unless his mounts somehow became solid, his engine should move as much as ours...care to explain?
liqalu04
Jan 2, 2022 12:58 PM
Jambo016
Sep 16, 2016 01:08 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
