fLUIDAMPR
Old Mar 23, 2006 | 12:11 AM
mchapman's Avatar
mchapman
Cool Richie, so you got it installed.
Where did you get it from?
Old Mar 23, 2006 | 12:49 AM
overZealous1's Avatar
overZealous1
Originally Posted by Resolute
This has nothing to do with the crank being balanced. Its a damper, not a balancer. You're crank is balnced so that it rotates smoothly wihtout extra mass on one side or the other to cause it to "wobble" while rotating. The engine still applies power in surges though. Every time a power stroke occurs is when your torque is made around the crank, and this process is not smooth over the course of the engine cycle. It comes in surges for every individual cylinder and this occurs at set intervals. This is a frequency, and this damper is designed to offset the frequencies of each individual power stroke from hitting the natural frequency of the steel used to make the crank. Using this will increase longevity and smoothness rather than make power. For a stock or mildly modified engine I wouldn't bother, but for high rpm use like Z350 Lover's 8000rpm screamer, I would think it to be a neccessity.
Will
well put. but the frequencies of the steel is far more tuning than any manufacturer is willing to deal with. meaning, fluidamper makes harmonics balancers for most any motor out there, and 3 types of widely used materials are out there being used. fluidamper makes the same balancer for all of them.
as will said, power is delivered in pulses, these pulses tend to try and torque bend the crank, the harmonic balancer is designed to dampen these pulses to help slow the torque bend and change the frequency.
i would not say rpm is the reason to run one. it is the same theory someone would put dynamat on a panel to dampen sound transfer, to a point. the balancer is designed to help crank twist frequencies. the frequencies caused be the crank snapping back into shape again.
so basically, another twist on the same thing will said, lol.
Old Mar 23, 2006 | 06:57 AM
dream724Z's Avatar
dream724Z
At $350 it earns the distinguished Title of the most expensive pulley by ~twice!
Old Mar 23, 2006 | 03:04 PM
Z350Lover's Avatar
Z350Lover
Murray,
I got it from Summit Racing.... www.summitracing.com
cheers,
richie
Old Sep 27, 2006 | 06:01 PM
NismoSaint's Avatar
NismoSaint
im a little confused what does this part replace , does it avoid having to get ..lets say ur pulley kit , i know its a newb ? but its the first tthing i've heard of these things, cause i have some engine vibration when rps get lower in the 3-2k range
Old Sep 27, 2006 | 07:05 PM
reptile718's Avatar
reptile718
so is this heavier then the stock piece? also how does it compare to it?
Old Sep 28, 2006 | 05:07 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
This part can be described as more of a safety/reliability enhancer rather than a power adder.
Old Oct 12, 2006 | 12:18 PM
trefling's Avatar
trefling
Very true! I've talked with a couple of people who have cracked the origional one with just 525rwhp. Anything over that and your taking a big change because if your crank pulley breaks things won't look good for the rest of the engine.
Old Oct 2, 2007 | 08:17 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
wow, i'm definitely bringing this one back from the dead! i finally installed it last week, just in time for raceday at buttonwillow.
anyway, here's a short review - it feels great! install was slightly more difficult than the UR because the Fluidampr is solid, no holes to put clamps or rope through to hold down while tightening. there are bolt holes, but i didn't have any bolts that would fit. so in order to get the crank bolt tightened down, i had to have someone hold down the brake really hard (while in 6th) while i tightened it 60 degrees (plus 36 ft-lbs).
during the install i also installed new belts. i did find that the alternator/ps belt was a little hard to get on. the diameter of the stock pulley and the fluidampr were the same. what i found surprising was that the fluidampr was actually about 0.5lb heavier than stock. i haven't had a chance to call fluidampr and ask about this, but i am sure it has something to do with the rotational "smoothness."
after the install, i turned it over a couple of times manually making sure there was no binding. after all was good, i started it and immediately i noticed a difference in the idle. it was much smoother than before. i did not get to test drive it however until track day. i was a little wary at first since the belts were brand new, but after a couple of warm up laps, i hammered it. even during the warm-up laps, i noticed how much smoother the engine felt throughout the rpm range. being a heavier pulley, i did not feel any increase in throttle response or power. i was not expecting it though since it is the same as the stock diameter and surprisingly a little heavier. however, i am very happy with it just with how much smoother the engine feels. i am sure it has added a few thousand miles to the life of the engine and maybe a few more track days (which was what i was looking for). i have seen a thread however which allowed an individual to boost about 3 more psi with a vortech supercharger and this damper. just thought i'd share...
Old Oct 2, 2007 | 11:42 PM
Quamen's Avatar
Quamen
I think that my $500 custom crank pulley takes the cake on this one. Lol.
My question is are these dampners supposed to absorb vibrations that would be harmful to the breaings or just the crank itself? Reason I ask is because if the rear cylinder fires the vibration would have to travel past every single bearing just to make it to the dampner. Is this a misconception? I could see it being used to keep vibrations from the accessories out of the engine.
Old Oct 3, 2007 | 01:38 PM
booger's Avatar
booger
I have the ATI damper at $400 . Use it to bolt up a cog pulley to it to run the blower .
Old Nov 12, 2007 | 01:18 PM
jonnylaw's Avatar
jonnylaw
The ATI weighs 6 pounds I believe
The ATI and fluidyne are more for FI and safety, while the UR ones are for more for NA and some gains?
Old Nov 12, 2007 | 03:28 PM
QuadCam's Avatar
QuadCam
Is it SFI rated?
Old Nov 12, 2007 | 05:03 PM
jonnylaw's Avatar
jonnylaw
Originally Posted by QuadCam
Is it SFI rated?
ATI's exceeds SFI 18.1 specs:
http://www.atiperformanceproducts.co.../damnissan.htm
Old Nov 13, 2007 | 05:03 AM
QuadCam's Avatar
QuadCam
Originally Posted by jonnylaw
The ATI units are really nice. If you are really serious, they will test your engine and determine exactly what it needs. Then, they built you a custom dampner!!!
JoeDirtPharmD
Jan 15, 2011 05:07 PM
streetrays
Jul 1, 2008 06:10 PM
n1cK!
Apr 23, 2005 12:47 AM
