replace 03 engine with 05 track engine?
Old May 19, 2005 | 09:50 PM
Z BOY's Avatar
Z BOY
Default replace 03 engine with 05 track engine?
this may be a stupid question, but i'm asking it anyway because tomorrow my dealer will let me know if they are gonna rebuild or replace my long block. The question is: if they choose to replace the engine, should i request the 05 track engine and pay the difference? Is it doable? keep in mind i am considering going FI eventually. Any help would be greatly appreciated, as i'm gonna have to pose this to them tomorrow. Thanx.
Old May 19, 2005 | 11:27 PM
thawk408's Avatar
thawk408
A guy a know calculated all the parts neccesary to convert the 287hp engine to the 300hp and it was somewhere around 7grand, but it is always worth a shot. Before you relly get into thinking about it I would go drive an 05 track(if you can find one) and see what you think. Good luck.
Old May 19, 2005 | 11:31 PM
Z BOY's Avatar
Z BOY
the 05 track crate engine is offered for $6100 at perf nissan. the non rev-up sells for like 5500.
hawk, have you driven both cars and if so, what were your impressions?
Old May 19, 2005 | 11:33 PM
Z BOY's Avatar
Z BOY
from perf nissan:
Product Name+ Price
OEM VQ35DE 350Z Engine Assembly - 2005 Track $6,100.00
OEM VQ35DE 350Z Engine Assembly 10/03 - 2004.5 $5,475.00
OEM VQ35DE 350Z Engine Assembly 5/03-7/04 $4,895.00
OEM VQ35DE 350Z Short Engine Assembly - 2005 Track $3,375.00
OEM VQ35DE 350Z Short Engine Assembly 05/03 - 2004.5 $2,850.00
Old May 20, 2005 | 08:39 AM
thawk408's Avatar
thawk408
So the engine assembly is actually the entire engine? If so, that doesn't seem like a bad price. I have driven a 287hp, but that was over half a year ago and I honestly can't remember. I will be gone this weekend, but when I get back I think I might be able to drive one and give you my thoughts.
Old May 20, 2005 | 08:43 AM
g356gear's Avatar
g356gear
That is the lonblock price....no harness on sensors or accessories. Be aware that the wiring harness is completely different on the 05 vq's....they have variable timing on intake and exhaust now so the wiring harness and pin locations on the ecu have changed. You can physically see the differences between the 2 motors if you go and see the new engine at a dealer....extra sensors and associated plugs.
ANXIOUZ's Avatar
ANXIOUZ
If you don't mind paying the difference, I think it would be cool to get the 05 Track engine. Newer is better right?
Old May 20, 2005 | 08:48 AM
Z BOY's Avatar
Z BOY
that's what i was thinking.
"So the engine assembly is actually the entire engine? If so, that doesn't seem like a bad price. I have driven a 287hp, but that was over half a year ago and I honestly can't remember. I will be gone this weekend, but when I get back I think I might be able to drive one and give you my thoughts."
thanx hawk, that would be great!
Old May 20, 2005 | 09:06 AM
Gman2004's Avatar
Gman2004
Originally Posted by Z BOY
from perf nissan:
Product Name+ Price
It would be nice if nissan just gave you a check for the 10/03 - 2004.5 $5,475.00 . You could get a built long block for almost that price. The one below is going all out with head work and cams and only cost about $2K more.
Upgraded Long Block #3: $7500
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*Ceramic coating on Pistons
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Old May 20, 2005 | 11:35 AM
Z BOY's Avatar
Z BOY
great idea. we'll see very soon.
Old May 20, 2005 | 01:15 PM
Road Warrior's Avatar
Road Warrior
thats way too much money for 13 hp....going from 03 to 05
Old May 20, 2005 | 02:30 PM
g356gear's Avatar
g356gear
It won't work!!
Old May 20, 2005 | 02:32 PM
sentry65's Avatar
sentry65
the burninator
yeah you need the 05 ECU too probably in order to get that 300hp or even to get the engine to work right
+1 on it won't work
Old May 20, 2005 | 02:46 PM
fernandito7's Avatar
fernandito7
Maybe this has been asked but why is nissan replacing ur engine?
Old May 20, 2005 | 02:57 PM
sentry65's Avatar
sentry65
the burninator
think it was excessive oil consumption?
Old May 20, 2005 | 06:25 PM
booger's Avatar
booger
If the ECU and wire loom is different...its not doable . Unless you really want to pay out the a$$ for it
Old May 20, 2005 | 08:09 PM
Z BOY's Avatar
Z BOY
that's right, sentry.
so its been two weeks, and i STILL don't know whether they're gonna rebuild or replace my engine. i guess warranty work goes to the bottom of their list.
if they replace it, fine. if they rebuild it, i'm gonna have them build up the bottom in prep for some kinda fi in the future. jason from performance recommended nismo connecting rod bolts, and i was considering nismo cams, fw/clutch. any other suggestions guys?
Old May 20, 2005 | 09:02 PM
nizmoz's Avatar
nizmoz
Guys,
I spoke with Tony at Performance Nissan today. I'm not sure that I have this completely correct, but my recollection is that he told me the following: The 2005 Track has OBD III instead of OBD II ECU technology. The OBD II ECU, heads and ports on the 2005 Track actually de-tune the car to meet new emissions. The step backwards is compensated for by the new VTC Cams and the new Lower Plenum.
My assumption (Tony did NOT state this) is that the most powerful possible combination will be a 2004 engine with a 2005 Track Lower Plenum and NISMO Cams.
My car has NISMO CAI, Cams, Headers and CBE. I'm gonna add the 2005 Track lower Plenum very soon and follow it up with a Technosquare re-flash. I might add an AAM or Motordyne plenum spacer but haven't seen any info on those spacers with the Track Lower Plenum. I will post the dyno figures.
Tony, apologies if I have any of this wrong! Thoughts/coments would be appreciated!
Old May 21, 2005 | 01:56 AM
the7ferret's Avatar
the7ferret
If your doing it for performance its the wrong way.
$6,100.00 for 13 HP?
Send me $6100 ill get your Z above way above 300 with plenty to spare...
However if nissan is replaceing yoru engine they will proably slap another 03 or 04 engine in it as they are the same.
Old May 21, 2005 | 10:02 AM
sentry65's Avatar
sentry65
the burninator
I hope it goes well, but the dealer probably won't have the capability to do any sort of built up engine, and they most likely won't wanna play ball with putting in the 05 track engine because no one knows if it will work and could end up costing them even more money to try to make it work, give up, and put a 03-04 engine in. This is especially true since the dealer usually has their hands tied behind their backs as far as experimenting. They gotta do stuff by the books so there's no potential for lawsuits because they didn't follow standard procedure.
my 2 cents. Good luck with it all though. If anything, just getting a new regular engine will be nice - you regain all your worn miles you've used on it
