Drive by wire
Old May 22, 2005 | 03:51 AM
ken350z's Avatar
ken350z
Default Drive by wire
I noticed that some other cars that have drive by wire have the ability to change the throttle profile.
Any way to do this with the Z?
Old May 26, 2005 | 04:34 PM
Chebosto's Avatar
Chebosto
the only current way to change the throttle position is via the ECU reflash.
http://www.technosquareinc.com/drivewire.htm
Old May 26, 2005 | 07:35 PM
Z350Lover's Avatar
Z350Lover
So does it mean that when you do the TS reflash to get up to 7000rpm (before this throttle position thing is introduced)... they also changed the throttle position?
cheers,
richie
Old May 26, 2005 | 08:33 PM
Aggro_Al's Avatar
Aggro_Al
Not sure if this is what you are looking for but, if you have the 5AT throttle tip-in is adaptable.
Old May 27, 2005 | 04:14 PM
Chebosto's Avatar
Chebosto
They stated that at higher rpms and WOT, the throttle isnt at 100% open in stock programming, (its even worse for automagics).. with their reflashing, they force the throttle to stay open throughout the powerband on WOT.
cheers,
richie
Old May 27, 2005 | 04:28 PM
Z350Lover's Avatar
Z350Lover
Chebosto:
Thanks for the info once again.... I just worry that I have got the fuel cut moved up to 7200rpm with "another computer" (piggy back the MoTeC, not through reflash, therefore, the standard rev-limiter 6600 is still in the standard computer, but not being used) while the throttle profile is retained as the standard setup (not 100% open at WOT).... and will this ever affect the power up from 6600rpm since they mention that the flap starts to close when it get closers to the rev limiter... as much as 20%...
cheers,
richie
Old May 28, 2005 | 04:43 AM
ken350z's Avatar
ken350z
By "throttle profile" I mean the position of the throttle vs. the amount of fuel applied. At least that's the best way I can verbalize it. Imagine the plot of the gas pedel movement on the x axis and the amount of acceleration?/fuel?/hp?/rpm? on the y axis. The graph produced would be the throttle profile.
I noticed that my Z with an AT takes a _very_ gentle touch on the pedal when stopped to keep it from jumping. I suspect that it was setup with the 0-60 times in mind. It might help the drivability to soften that up a little.
In my 6-12 month search for a new car I noticed that at least one of the drive-by-wire cars had a **** on the dash that allowed you to select the profile.
Old May 28, 2005 | 08:27 AM
RA11325's Avatar
RA11325
i assume you mean the M3, you can adjust throttle sensitivity, say in normal mode a blip of the throttle will yield a small jump in rpms, while in aggresive mode a blip with equal a jab of the throttle.
Old May 28, 2005 | 01:47 PM
ken350z's Avatar
ken350z
It could have been the M3.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
