My REview: Cusco RS Type LSD
Old Jun 10, 2005 | 10:25 PM
daytona350z's Avatar
daytona350z
basically, since it a locking lsd, it will try to make the two driving wheels spin at the same speed. when driving fast and constantly braking/accelerating and shifting, you will have to be smooth or else it will essentially lock the wheels, causing the car to "kick" out when you downshift and let the clutch out too fast.
im not to great with words, im sure someone can explain further into detail though.
Originally Posted by mchapman
Nice review,
Mountain/spirited driving:
a couple days later, i took the car up to ortega hwy. a small run through to test the car out.
wow describes what i felt. no more "twitchiness" with the rear. it was planted and i could put the car where i wanted to. i gained alot of confidence by just this single mod.
yes, you do have to watch out because of the 2-way setup. it will surprise you if you do not know how to drive it fast.
Can you give further detail on what you have to watch out for when driving the 2-way LSD fast?
Old Jun 12, 2005 | 10:27 AM
ihatethatbobbarker's Avatar
ihatethatbobbarker
talking **** on my lsd *****, :P
i need to drive yours on the 18th and see how different it grips.
Old Jun 12, 2005 | 10:32 AM
daytona350z
if you let me drive yours of course
Old Jun 12, 2005 | 08:38 PM
thawk408's Avatar
thawk408
So what makes this one quieter then the Nismo?
Old Jun 12, 2005 | 09:04 PM
daytona350z
the fact that this lsd is spring loaded instead of using the regular cone type plates.
"The Type RS is a low initial torque type using RS springs. With the Type RS, the initial torque is absorbed by the RS springs therefore the initial torque comes on gently compared to the Type MZ which comes on stronger as it uses cone plates and response of the LSD is better, as the friction is lower."
Old Jun 12, 2005 | 09:16 PM
illZ's Avatar
illZ
good info!
getting 3.917 and some kind of aftermarket LSD this week.
Old Jun 14, 2005 | 08:34 PM
imoz's Avatar
imoz
Nice write up. This is making me rethink the Nismo LSD and lean towards other options.
Old Jun 14, 2005 | 08:58 PM
ihatethatbobbarker
dude, rock the OS giken!
Old Jun 15, 2005 | 04:37 PM
daytona350z
OS giken....drool......
Old Jun 18, 2005 | 11:38 AM
Peking's Avatar
Peking
Got mine early this month, no need to worry about the pumkin right? Should pretty much fit within the OEM setup?
Also is it normal to install then fill, then after 500 miles or so drain then refill?
Old Jun 18, 2005 | 04:29 PM
ihatethatbobbarker
what trim level do you have
Old Jun 18, 2005 | 05:42 PM
Peking's Avatar
Peking
Talking to me? If so Base version.
Old Jun 18, 2005 | 06:41 PM
Machupo's Avatar
Machupo
make sure you get the axles stubs then...
Old Jun 18, 2005 | 07:07 PM
ihatethatbobbarker
yep, might need bearings and stuff too, what i bought came with everything though
Old Jun 19, 2005 | 05:52 AM
daytona350z
you need axle stubs, 2 oil seals, and 2 differentail bearings.
Old Jun 19, 2005 | 09:10 AM
Peking's Avatar
Peking
Thanks guys, hopefully I will check with the shop ahead of time to see if they have these items on hand or can get them
Old Jun 21, 2005 | 04:09 AM
MR RIZK's Avatar
MR RIZK
After searching and reading through a few threads I have decided to go with the Cusco RS but when I enquired about this unit they mentioned that there were the following models in the RS range:
1 & 2way version or
1.5 & 2way version
The question is which is better suited for me. My main use of the car is going through the twisties and the occasional track work. I do not drift nor do I intend to (on purpose anyway)
Now speaking with a few guys they all mention that the 2 way is mainly for drift but reading the threads most guys use the 2 way for the track so a little lost to make a decision.
Michael
Old Jun 21, 2005 | 04:52 AM
  #38
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they are the same exact unit - one comes preset at 2 way, and can be adjusted to 1.5 way and the other comes set at 1.5 way and can be adjusted for 2 way
I cannot imagine driving a car with a 2 way diff all the time unless I revelled in hanging the tail out sideways - 1.5 way is far more useable, especially for street, but also on the track IMHO
Old Jun 21, 2005 | 05:27 AM
  #39
MR RIZK's Avatar
MR RIZK
I found this image on the ATS site which answers most of it for me
http://www.a-t-s.co.jp/e-atsgif/2way.gif
Old Jun 21, 2005 | 06:59 AM
  #40
illZ's Avatar
illZ
Doesn't OS Giken make the Cusco/Nismo??
