High Clutch? want to lower your clutch engagement point?
Old May 8, 2014 | 08:28 PM
  #461
Zelda06's Avatar
Zelda06
Very excited that I found this thread. The clutch is unbearable for me (compared to other manuals I have driven), so hopefully I can get this started on mine.
Old May 14, 2014 | 12:01 PM
  #462
harmony350z's Avatar
harmony350z
i believe there was a guy here on the forum that made a kit to make your clutch pedal with lower engagement point. forgot the name of his kit. Unlike turning the **** behind your clutch for risking engagement all the time . This kit actually required you to take out ur clutch pedal and mount it on the kit. i got order mine and man it makes a big difference. you still get your clutch pedal travel distance like oem, but you get a lower engagement too. you barely lift your foot of clutch and car already engage. the kit will also work if you have cruise control too. it has mounting bracket for cruise control button.
Old Jun 21, 2014 | 04:05 PM
  #463
djake's Avatar
djake
Just did this adjustment and man is it awesome! I no longer feel like I'm driving a semi-truck. I adjusted it to be about even with the brake pedal and love it.
Old Jul 6, 2014 | 07:17 PM
  #464
cashmoney03's Avatar
cashmoney03
Adjusted mine today. Did 3 turns. I like it. Definitely a much more responsive clutch.
Old Jan 25, 2015 | 11:37 AM
  #465
blueman's Avatar
blueman
Ha long time between comments... Just bought my first 350.... Been a maxima driver and fan for years and was about to pull the trigger on a 15 Nizmo but decided for a 3rd car it was a bit pricey.... The Nissan guy called me and said you have got to come look at the 08 350Z that just got traded 12k original 1 owner car! Needless to say I bought it and went to pick it up and stalled it 3 times on the way home this thread is AWESOME I made the mod this AM and it's a totally different car... Thanks from a old fart checking off my when I'm 50 bucket list ✌️
Old Jan 25, 2015 | 11:41 AM
  #466
blueman's Avatar
blueman
Old Apr 19, 2015 | 05:30 PM
  #467
dSpaceman's Avatar
dSpaceman
Attempted this today and gave up. Even removing the dead pedal there was little to no room to work with. Just an FYI, the dead pedal does not just pop out, you need to unscrew the 5 screws ontop and remove the aluminum plate first, then turn the two screws underneath. Almost broke mine cause I thought it just "popped out" like OP said
Old Jan 25, 2017 | 03:48 PM
  #468
KRiSXC0RE's Avatar
KRiSXC0RE
I performed this adjustment today and it makes a huge difference! My only regret is that I didn't come across this thread sooner. Anyway, just wanted to say thanks for the helpful info!
Old Jan 25, 2017 | 08:00 PM
  #469
speeddream's Avatar
speeddream
Came across this at the best time. Subd
Old Feb 28, 2017 | 10:57 AM
  #470
trusovici's Avatar
trusovici
super old thread but wanted to chime in and say thanks to everyone that contributed. I finally got around to changing the clutch slave and master. When i replaced the clutch master i tried getting the travel the same as stock but went a mm or so too long and the engagement was higher than what it was before. I turned the pushrod so as to screw into the clevis (shorten it up) and went way too short the first time leaving me with a sticky pedal. adjusted a few more times to get it where I wanted.
Better to make small adjustments at first.
now i can burn out from first to second without grinding second gear, the 350z clutch master cylinder is prone to getting dirty and failing.
in reference to the dead pedal, it does just pop off, no need to unscrew the plate.
Old Jul 9, 2017 | 12:40 PM
  #471
Edneil Sundar's Avatar
Edneil Sundar
Can anyone update and let us know how many years/miles went by since this mod? And how many threads shown on rod like in OP pic which he has 3 threads showing (about 4 turns)
EnjukuRacing
Sep 30, 2015 06:55 AM
