Taller Gears
Asked this in the general mod thread, didn't get much reply.
I clarified that the AT Final Drive for our car is a 3.3 as opposed to the stock 3.5.
Is that the only option, switch to the AT final drive? Or are there other products out there?
(Edit)
Looking to go taller by the way not the 3.9 from Evo
~Josh
(Edit)
~Josh
It is 3.3 and unless you go FI you wont see the benefits but rather see a reduction in accel.
As for losing 60' times you gain it back by not having to shift into 5th at the end of the 1/4 mile, with FI you are trapping 112+ and 4th gear maxes out around 110 with 3.5 but goes to 120+ with 3.3
I am going FI. APS Single Turbo. I'm looking to make the 400 RWHP a little more managable. Figured that a 3.3 will give me better real world accel because I will have a easier time with 1st and 2nd gear.
Originally Posted by westpak
It is 3.3 and unless you go FI you wont see the benefits but rather see a reduction in accel...you gain it back by not having to shift into 5th at the end of the 1/4 mile... with FI you are trapping 112+ and 4th gear maxes out around 110 with 3.5 but goes to 120+ with 3.3
Originally Posted by bullseye
Correct. My G35s' 5AT tranny shifts from 4th into 5th at about 128-130mph.
Originally Posted by sentry65
just curious, can you put in the 3.9 gears and launch with 2nd gear? Or is that not such a great idea?
That would kind of defeat the purpose of changing the gear out...plus it would put quite a beating on your clutch to get the car out of the hole in any quick manner.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
