The million dollar question.....
Old Aug 14, 2005 | 11:44 AM
Speedracer's Avatar
Speedracer
Default The million dollar question.....
Anyone know how difficult it would be to transplant the 300hp motor into a 287hp motor car. Other than the engine, primary ECU harness and ECU, would anything else be needed? Has anyone done this yet?
Old Aug 14, 2005 | 11:49 AM
Zexy's Avatar
Zexy
I'm sure it won't be too dificult? But definately not worth it.
Old Aug 14, 2005 | 11:53 AM
LaoSiFu's Avatar
LaoSiFu
I would rather spend all that money (parts and labor) into aftermarket parts.
Old Aug 14, 2005 | 12:44 PM
sentry65's Avatar
sentry65
the burninator
you'd need an 05 ECU and maybe some extra wiring or an EMS
the 03 and 04 ECU has no idea how to handle the VTC and cams and the 7000 rpm redline - it wouldn't know the engine has those capabilities
you are MUCH better off just buying an 05
...I wouldn't bother unless you were going FI and were going to build up an engine and use an EMS anyway
Old Aug 14, 2005 | 02:38 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
some people depending no the class they run in have to run a stock motor...
it would be very $
there are other options you can do, are you trying to stick to a certain race class?
Old Aug 15, 2005 | 04:18 AM
Speedracer's Avatar
Speedracer
it would be very $
No.... it was more of a curiosity question than anything else. The new engine may also have strong enough connecting rods to better handle a modest forced induction system, and a new strong enough factory assembled power plant for $8000 seems like a viable alternative to pulling your motor, ripping it apart, rebuilding it and re-installing it. Also, the variable timing control does have the potential to make the car more responsive to NA mods. Finally, in terms of smoothness and feel, it is simply a better motor
Old Aug 15, 2005 | 07:55 AM
theking's Avatar
theking
For $8000 including pulling and installing the motor you can have one hell of a custom built motor.
Old Aug 15, 2005 | 01:53 PM
HockeyZ39's Avatar
HockeyZ39
doesnt the 300 hp motor have 14 less tq than the 287 also?
Old Aug 15, 2005 | 04:16 PM
sentry65's Avatar
sentry65
the burninator
yup, around the midrange rpms
Old Aug 17, 2005 | 12:33 PM
Gman2004's Avatar
Gman2004
This the motor I have.....way better than a stock 05 motor and less expensive.
Upgraded Long Block #3: $7500 Good up to 850 Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Old Aug 17, 2005 | 07:01 PM
Jason@Performance
Performance Nissan
Thats awesome... But you also eliminated your self from alot of SCCA race events..
If you are building a car for SCCA or other groups, you have to have your car modded with specific mods... There is nothing against using the 300HP motor, but in the same class you cant change the intake...
Old Aug 18, 2005 | 06:07 AM
Speedracer's Avatar
Speedracer
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Heads redecked
*JWT Upgraded Cams
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
I know about SGP racing. Has anyone done a high compresion NA build-up from them or someone else. What is required for the engine management and is it emissions legal?
Old Aug 18, 2005 | 07:01 AM
Gman2004's Avatar
Gman2004
I haven't seen or read of anyone doing this. After all is said and down it is not worth the money for the hp you get.
Old Aug 18, 2005 | 08:01 AM
Qbrozen's Avatar
Qbrozen
I'm trying to understand why you would want less torque...
Are you guessing that it has better internals? Or is this a fact? i would find it hard to fathom why Nissan would put so much money into a different engine just to get the magic 300 hp number when a few external mods would do the trick. So I'm doubtful there is anything significantly different between the 2 engines .... but its not like I haven't been wrong before.
Old Aug 18, 2005 | 08:04 AM
Jason@Performance
Performance Nissan
peak torque.. but the torque curve is different... you have more torque in higher rpm's then the other motor...
you can have all the turque you want down low... That doesnt help you when you are 5000RPM - 7000RPM (road course)
gc350z03
Oct 28, 2016 05:00 PM
Upstreammiami
Sep 17, 2015 02:45 AM
h8redlights
Sep 11, 2015 07:57 PM
BullishZ
Jul 18, 2002 06:13 AM
