replacing my clutch
Old Nov 7, 2005 | 08:20 AM
DRFT_350Z's Avatar
DRFT_350Z
Default replacing my clutch
hey i was going to replace my clutch but it turns out it will cost me 1400 dollars to replace my clutch at nissan so i thought i can get a mechanic to do the job but anyways the stock nissan clutch was way to expensive and i have a friend that can get me a brand new clutch from a G35 for a lot cheaper, now my question is if anyone knows that if the g35 clutch will work on my Z, i figured it would since they are pratically the same car but if any one knows for sure that would cool.
Old Nov 7, 2005 | 08:30 AM
Nitrouz's Avatar
Nitrouz
Back to Z
$1400??? Why don't you get an aftermarket one then?
Old Nov 7, 2005 | 08:34 AM
DRFT_350Z's Avatar
DRFT_350Z
i was going to but i also need brake pads, alignment and stuff i want to be able to drive my car sooner so it would be a lot cheaper if i went with the g35 parts
Old Nov 7, 2005 | 09:20 AM
Consider buying the clutch from Nissan, and having a reputable shop (other than Nissan) install it.
Old Nov 7, 2005 | 11:11 AM
isugoo's Avatar
isugoo
My Z is at the dealership now for clutch/flywheel replace.
Labor was 505.00 and as long as I know Nissan stock clutch is alot cheaper then aftermarket according to Performance webste price. (mynismo.com)
I don't know what your dealer is thinking about...
Old Nov 7, 2005 | 12:25 PM
tmounk's Avatar
tmounk
If your car is under 30,000 miles, the clutch is still under warrenty, I don't know how that works or what type of magic you have to perform to get that. Nissan warrenty is not that friendly to 350z.
Old Nov 7, 2005 | 12:50 PM
Aced16's Avatar
Aced16
i dont think so, i maybe wrong, but doesnt that fall under wear and tear????
Old Nov 7, 2005 | 12:55 PM
Swiffer's Avatar
Swiffer
Thats correct. Clutches are only replaced if the clutch is found to be faulty. They are not replaced under regular or improper use.
Old Nov 7, 2005 | 01:49 PM
CLETUS's Avatar
CLETUS
clutch is a wear item like brake pads and wiper blades......unless a spring on hte clutch disc fails or the pressure plate breaks (even then they will probably blame the failure on driving style........you have to play your cards just right to get a clutch replaced under warranty...... they will turn it down pretty much unless it fails right away.
Old Nov 7, 2005 | 03:30 PM
spdkils's Avatar
spdkils
I just had my clutch replaced for 305 bucks in labor @ clutch doctors.
Of course I put in an expensive ATS twin carbon clutch, so the total bill was a bit more... But 300 bucks in labor is pretty cheap.
My stock clutch only has 7000 miles on it... (Sitting in a box now.)
Maybe you can get a used one with low miliage... Lots of people have done clutch replacements around here.
Old Nov 7, 2005 | 03:39 PM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
$500 is okay for a clutch job....with that said, I wouldn't spend that much money on a stock clutch tho. I think its a rip off. We have a ACT street disc here for much cheaper if you are interested.
Thanks,
Tom
07ZEKE
Aug 23, 2021 09:15 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
