Grounding Kit..................Whatever
Old Nov 21, 2005 | 09:40 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Originally Posted by Hydrazine
Whats the Grounding Kit Install plot for?
X axis = RPM, RPM Average, or mabey time weighted average?
Y = Units of time?
No grind or anything. I'm just curious.
I think it is magnified 100x so you can see the difference in HP that the grounding kit adds. The vertical scale is in 1/10 hp increments.
When I want to smooth the idle out, I turn on the AC.
Chris
Old Nov 21, 2005 | 10:11 AM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
i do believe the grounding kit DOES provide benefit. simply saying a circuit is either grounded or not is just not true. a good ground will provide a more consistent voltage with less flucation than a poor ground. and that is what most grounding kits are advertising they provide. a more robust ground to level out voltage fluctuations if i understand them correctly.
as an example consider power sources. you wouldn't say a power source either provides current or it doesn't. while they may provide the same peak voltage and current ratings, some deliver it smoothly and others suffer from noise or voltage fluctuations. the idea is to minimize the noise and fluctuations of the power source to provide a smoother delivery of current. if a grounding kit can do that then it works and has benefit.
that said. hp claims on grounding kits are arguably questionable. since the hp gains in question are so small it's difficult to determine if the gains are from the grounding kit or simply fluctuations between runs.
Old Nov 21, 2005 | 11:57 AM
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
Default RPM vs. Frequency
Y = Units of time?
Sorry about that. RPM vs. Frequency.
BTW, I hardly feel grinded. I am always open for questions
Old Nov 21, 2005 | 12:04 PM
insaneamine
Inventor
Z-Xtreme.com
Default I meant to ad this
Here are the actual data points collected. Top row w/o kit, Bottom row w/ kit.
File Type: bmp
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
