clutch just started slipping, how long till it dies?
Old Nov 28, 2005 | 11:01 PM
EdgeOfSanity's Avatar
EdgeOfSanity
Default clutch just started slipping, how long till it dies?
I have just over 28,000 miles on my z and my clutch has finally started to slip. I've noticed it three times today. Twice while coming up my driveway while downshifting to second at low rpm then giving it some gas and once tonight while cruising in fifth gear. I learned to drive a manual in this car on this clutch and i did manage to burn it for about 2 seconds on a hill when i first got it. Its been to the dragstrip at least 10 times and has made at least 30 passes. This is the first manual car i've owned so i have no idea how long till a slipping clutch dies. Can anyone guestimate on how long till it gives out?
Old Nov 28, 2005 | 11:18 PM
JETPILOT's Avatar
JETPILOT
Slipping clutch = Dead Clutch. 28,000.... that's about half the normal life of a clutch.
Respect
JET
Old Nov 29, 2005 | 06:37 AM
cessna's Avatar
cessna
Easy on it, should last for another 5000kms.....(hopefully)
Old Nov 29, 2005 | 06:52 AM
Vamos_Rafael's Avatar
Vamos_Rafael
whats the symptoms?
Old Nov 29, 2005 | 07:45 AM
Here's what will happen: you’ll be driving 60 mph, and attempt to come to a stop. The brakes will work fine, but when you push in the clutch it will NOT disengage.
Old Nov 29, 2005 | 08:05 AM
EdgeOfSanity
Originally Posted by jvanquish
whats the symptoms?
rpms rise but the car goes nowhere, then it grabs and gives the car a nice little jerk forward.
Old Nov 29, 2005 | 08:50 AM
overZealous1's Avatar
overZealous1
ya, time to fix now.
Old Nov 29, 2005 | 08:56 AM
barthelb's Avatar
barthelb
Master
Sounds like slippage but maybe an adjustment can help?
Old Nov 29, 2005 | 10:43 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Most likely if it only slips now when racing-if you drive easy it can last you a LONG time. Buddy of mine started to slip when racing, he stoped racing, 50K miles later he still runs that old POS clutch. If you plan on racing it it will get much worse much sooner. You can baby it a while till you save up $$$ for a clutch/fw...
Old Nov 29, 2005 | 11:07 AM
EdgeOfSanity
i can buy the new clutch/flywheel whenever, but i have to give up on the new computer i was about to buy if i do so. Anyone know what most shops charge for a flywheel/clutch install?
Old Nov 29, 2005 | 11:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Most shops will charge $350-450....$300 or lower would imo be resonable.
loudtoyz
Apr 6, 2023 04:52 AM
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
