Cams with rev-up motor
Does anyone know if anyone has cams out that will work with the new rev-up motor. I was having some JWt's installed in my motor and we found out that they wont work b/c of the variable cam timeing system.
The cam gears wont mount up right. ON JWT's site is says that they will not work exhaust cam control
http://www.jimwolftechnology.com/cus...asp?PartID=443
They will not work on the rev-up motor because the exhaust cam is not made to work with the exhaust cam timing. No one at the moment that I know of makes cams for the rev-up motor. You might be able to get a custom ground set, but you would need to find out the factory rev-up cam profiles and I have searched high and low and still can't find them.
When i last talked to SGP they said that JWT was working on them right now so im hopeing they will come out soon(within the next month) or I will look into gettting a custum set ground.
I havent looked for them yet, i have the 2005 service manual so maybe it has them, ill check when i get home. I was thinking a cam company would be able to figure out the profiles if i provide them with the factory ones and go from there.
I had orginaly planned on pulling the JWT's when i found that the stock rev-up cams were close to them and go with something more aggressive, but now nothing will work but the stock cams and i just found out that the blanks are not available yet either so no one can make a custom ground set either.
Performance Nissan
Performance Nissan
There is no pins sticking out of the exhaust cams to work with the Variable Exhaust Timing...
However... Those with a 287 motor withOUT exhaust timing, you can grind these off and use the cams on the 287 motor! Less expensive cam option (and since its factory parts you can use in T2 racing)
unfortunatly there are no cam blanks yet for the exhaust cams with exhaust timing :-/
Performance Nissan
Performance Nissan
Originally Posted by Ep3
so what about a full head swap? im sure he could find heads for $500 used or swap with some one with a non rev motor but how would a non rev motor act with the full intact head of the rev up? <sorry for rambling>
you will:
Loose the exhaust cam timing:
Have to change your Frotn Cover:
Have to change your pistons since the deck of the 287 heads is different:
Have to do everything that is required to change the pistons (rebuild whole motor basicly)
if you change the heads...
you will:
you will:
Performance Nissan
Performance Nissan
These cams have an aggressive enough grind, and with the variable intake and exhaust timing, timing can be adjusted to even more extreems with this set up... im not sure i would jump so far to change cams on this motor just yet... I would mess more with the cam timing first...
Messing with the cam timing is nice idea, but b/c of what it costs to install cams later is making me reconsider. Does anyone know the lift/duration/etc. of the stock rev-up motor cams?
