PLEASE need help to go faster!
Old Jan 17, 2006 | 06:05 PM
lowlife350Z's Avatar
lowlife350Z
Default PLEASE need help to go faster!
Hi I have a 2003 350Z with DC headers, HKS cat back exhaust, AEM pully kit, AEM cold air, kinetix SSV manifold and kinetix cats that I dont use. I dont want to go the turbo or supercharger route and was curious what you guys think I should do next to get another 20-40hp if possible? Please help dont know what to buy next. cams? ecu? HELP!
Old Jan 17, 2006 | 06:49 PM
D350Z10's Avatar
D350Z10
Cams, UTEC, with a solid tune should be close or at 300whp and thats 375ish crank hp.... which low to mid 12's easier to get traction!
Old Jan 17, 2006 | 06:53 PM
faster than u's Avatar
faster than u
Nitrous= fast= extra 100hp = around 500$
Old Jan 17, 2006 | 06:54 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Well if you're talking about acceleration, I'd suggest getting the 3.9 final drive. You can even further improve that by getting a lightened flywheel. Also, you'll need to make sure you get plenty of traction so a good set of sticky tires will help as well as taking out excess weight (weight reduction). If that still doesn't make you happy, slap on a bottle.
Old Jan 17, 2006 | 07:00 PM
faster than u
just get nitrous and run 12s and make 03 04 cobras pissed
Old Jan 17, 2006 | 10:18 PM
steela2110's Avatar
steela2110
All of the guys who have replied each have made great points... If you want to go faster but dont want to go FI then you are going to need to do the following:
Evo 3.9 final drive gears
Cams
Grounding kit (not much but can help a little)
Get rid of your cats and do something like test pipes
Some sort of piggyback such as UTEC or UNICHIP
And lastly... You need to have someone tune your car who knows what the hell he is doin!
Old Jan 18, 2006 | 09:09 PM
Dubai's Avatar
Dubai
Add to list of mods you said, a CAMS and a solid tuning with UTEC and you should achieve your goal
Old Jan 19, 2006 | 07:48 PM
lowlife350Z
Thanks for the replies I forgot to add that I do have stillen lightweight flywheel and a bully clutch. but which cams sould I get,where can I get utec and a better final drive ratio? Also does anyone know where I can get it tuned around montreal or 3-5 hours from here? I know im asking for alot
Thanks!
samansharif
Sep 25, 2015 12:31 PM
