2006 Grand Touring
Old Jan 20, 2006 | 04:42 PM
JohnnyZ's Avatar
JohnnyZ
Default 2006 Grand Touring
Just traded in my 04 350 automatic for a 6 sp 06 Grand Touring. Won't get it til April. Can I pull my Borla Cat back from the 04 automatic and put it on the 06 stick? Also the injen cold air ind. will be swapped. Next step is the plenum. Can I go with the spacer or the full upper plenum? I don't want to sacrifice the stabilizer bar. Thanks
Old Jan 22, 2006 | 04:21 PM
Kiamo's Avatar
Kiamo
The intake/exhaust should swap on fine. As for the plenum, if you get a larger one that makes the factory stabilizer bar not work, you can get an aftermarket bar (such as Crawford's) so you still have one.
Old Jan 23, 2006 | 06:10 AM
JohnnyZ's Avatar
JohnnyZ
Does anyone know if the plenum on the 06 is one of the 35 new modifications?
Old Jan 23, 2006 | 09:10 AM
Kiamo's Avatar
Kiamo
The lower plenum is different. The upper plenum, AFIAK, is identical.
Old Jan 25, 2006 | 08:05 PM
J3rzeyFlip's Avatar
J3rzeyFlip
was ur 04 paid for before u traded it for the 06? If not, how much $ did u loose from the trade in?
Old Jan 25, 2006 | 10:06 PM
ZON's Avatar
ZON
That's such a nice model, the GT. I know you are going to love that one.
Old Jan 26, 2006 | 02:35 PM
steakpinoy's Avatar
steakpinoy
You shouldn't have a problem switching over your old intake and exhaust to the GT. As for a spacer, I would recommend getting the motordyne 5/16" MREV spacer kit for your car. It's basically the standard 5/16" spacer combined with a modified lower plenum (basically the lower plenum from the 03-04 models). from what I've read and heard from Tony from Motordyne, using a standard spacer without modified runners on the REV-UP engines will produce negligible gains. using the MREV kit, you lose 2-3 HP up top, but gain 15+ hp in the low to mid range. If you want to see more of it, you should check out www.motordyneengineering.com for more info or call performance nissan of duarte (www.mynismo.com). Ask for Andy; he has the REV-UP engine and the motordyne MREV kit, he can tell you about the gains. Hope this helps. Enjoy your new GT btw
Old Jan 26, 2006 | 02:37 PM
steakpinoy's Avatar
steakpinoy
Also forgot to mention; using the motordyne 5/16" mrev kit also allows you to keep your stock strut bar and engine cover; a plus when you're trying to keep a stealth engine profile. The spacers also help with low and mid range gains on FI if you ever decide to go that route.
Old Jan 26, 2006 | 04:40 PM
JohnnyZ's Avatar
JohnnyZ
rersponse to ? from J3rzeyFlip - I actually made out better with the trade in than with an outright buy. Probably because I only have 18,000 mi. on the car with stock Z chromed wheels, nismo type rear spoiler and super clean car!
Old Feb 8, 2006 | 03:55 PM
JohnnyZ's Avatar
JohnnyZ
Has anyone ordered a 2006 and received it yet? How long did it take from the date of order?
Old Feb 8, 2006 | 04:19 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Actually picked mine up today, but mine wasn't ordered. It takes 6-8 weeks to get it from the factory to your dealership.
Old Feb 8, 2006 | 04:30 PM
JonsilvZ's Avatar
JonsilvZ
You must have took a huge lose. Did you know that the GT is 250lbs more then the 04 you had? I dont think its worth the lose.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
3vilbunny
Jul 18, 2017 05:10 PM
Jambo016
Sep 16, 2016 01:08 PM
