what are these... cams..
Old Jan 23, 2006 | 08:35 PM
AvengerZ's Avatar
AvengerZ
Default what are these... cams..
http://cgi.ebay.com/ebaymotors/CAMS-...spagenameZWD1V
is it a joke?
Old Jan 23, 2006 | 08:38 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Originally Posted by AvengerZ
they give you a link for a discussion about it.
http://www.nissanclub.com/forums/sho...&page=15&pp=15
Old Jan 23, 2006 | 08:50 PM
AvengerZ's Avatar
AvengerZ
wow thanks
Old Jan 23, 2006 | 10:34 PM
overZealous1's Avatar
overZealous1
hmmm, havn't seen to many billet cams with a black coating on the lobes. not to sure what to think about that one. he has good feedback though.
Old Jan 24, 2006 | 09:11 AM
johnlotusboy's Avatar
johnlotusboy
Need to get them on a real "Cam Doctor" to profile and degree. Unmeasurable variances of cam timing (lobe position)1/2degree or more makes a lope in the idle due to different cylinder fill rates.
I would question if any current cams are that good, OEM has been know to vary a lot but the lack of idle overlap hides these symptoms.
The SBC cams we look at are real scary quality, even the big companies have loose tolerances.
Only cam grinds I've seen that had 1/4 degree accuracy are from Comp Cams.
After I have plotted flow vs. lift on my modded heads I will get Comp to grind some blanks for me.
Still need to finish oversize valve+spring pkg install from Ferrea, finish flow work, cc heads w/new valves then have Diamond Racing make custom piston.
Maybe running new motor in a couple months.
Old Jan 24, 2006 | 09:14 AM
johnlotusboy
I know that isn't casidium coating at least(too bad), it cost more than the cams do.
Old Jan 24, 2006 | 10:03 AM
AvengerZ's Avatar
AvengerZ
are you saying our OEM cams aren't that well made??!!?!
Old Jan 24, 2006 | 10:26 AM
If you reference the listing, and the listing references this thread, then this could go in circles until the end of time right?
Old Jan 24, 2006 | 07:41 PM
johnlotusboy
Most OEM cams aren't that good, look at LS1 cams, comp cams make lots more power, less emissions and better MPG than the Oem ones.
We currently run a .540/300degree in a street SBC idle at 650rpm in drive and pulls enough vaccuum for power brake. Motor has 300+cfm Brodix heads w/open plenum ----"No Lope". The whole motor was flowbench balanced for every port. Pulls past 8000rpm.
My motor shop does formula atlantic 4age motors, sprint car (gas/alcohol), drag blower motors, exotic(Ferrari/Lotus/Lambo), vintage restoration.
If it has pistons it can be fixed or better Crosly Hot shot, Packard, You name it, if the parts need to be custom fabbed it's just time and MONEY
And yes most factory cams have less than 2 degrees of wander to the lobes but it's kinda like ignition timing, 1/4 degree is very smooth and produces a much smoother better running motor.
A lot of after market Chevy cams were around 4 degree (Crane, Crower, all the big names) .
Crane is suppose to have the new equipment like Comp cams, but I haven't verified this.
Old Jan 24, 2006 | 08:56 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Old Jan 25, 2006 | 09:58 AM
AvengerZ's Avatar
AvengerZ
Talking
that was very educational... thank you!!!
Old Jan 25, 2006 | 01:30 PM
raptorbh12's Avatar
raptorbh12
wow after reading up on them they seem very reputable and proven to add 20hp on an altima. The guy even gave a member of nissanclub.com a free set to prove they are the real deal. for $600 i would say these are a steal.
bleunetizen
Jul 2, 2011 12:26 AM
DavesZ#3
Oct 8, 2006 05:58 PM
Juanito350Z
Jul 23, 2006 05:01 PM
KDW2002
Apr 6, 2006 04:34 PM
altimateone
Nov 19, 2005 07:16 AM
