Signs that transmission needs to be replaced?
Old Feb 8, 2006 | 11:45 AM
sal501's Avatar
sal501
Default Signs that transmission needs to be replaced?
I know few of you have replaced trannies. When do you know , it is time to replace tranny. What kind of problems you see for transmission going bad? Are there any tests?
I have owned Z for almost 3 years now, wondering if I need to check tranny before 36 months warranty runs out.
Thanks a lot
Old Feb 8, 2006 | 12:55 PM
97supratt's Avatar
97supratt
I think the obvious thing is if your shifter pops out of gear, its time for the tranny to go... lol
Old Feb 8, 2006 | 12:58 PM
sq40's Avatar
sq40
Red Fluid on the Ground is a sure sign something is wrong.
Old Feb 8, 2006 | 01:05 PM
athenG's Avatar
athenG
Thanks a lot
If you dont notice anything right now then your Tranny is good...
Old Feb 8, 2006 | 01:18 PM
showstoppertk's Avatar
showstoppertk
if you start experiencing grinding or popping out of gear/slipage then its time for a new tranny. however your powertrain warranty will cover the tranny till 5y/50k miles so don't worry about it unless its giving you problems.
Old Feb 8, 2006 | 07:23 PM
sal501's Avatar
sal501
Thanks all for the reply. the only thing I have noticed is that sometimes when i depress the clutch either in first or second in the morning, it makes a chatter at under 2500RPM. Seems to go away when the car is warmed up. Occasionally happens once in a while depending on if RPM is low.
Is it normal?
Old Feb 9, 2006 | 10:44 AM
97supratt's Avatar
97supratt
Is it normal?
This has been happening to my 06 ever since I bought the damn thing. I'm not sure if its normal, I just thought it was. Nothing is really normal about these damn trannies on the 350z's though.
Old Feb 9, 2006 | 11:17 AM
theking's Avatar
theking
Sounds like the synchros and it is normal. Grinding while going into gear(mostly 3rd and 5th) and popping out of gear are the tell-tale signs.
Is it normal?
Old Feb 16, 2006 | 07:14 AM
BrianLG35C's Avatar
BrianLG35C
I'm frequently getting the grinding when going into 3rd gear (like I've missed a shift and eating teeth) and during it's first few minutes of operation but once it's warmed up it doesn't happen as much. Is this a symptom of needing a new transmission or what parts are going bad? Is it my flywheel?
This seemed to just start happening the last few months or am I just forgeting to engage the clutch all the way before throwing it into 3rd? Could this just be lazy shifting?
Old Feb 16, 2006 | 01:29 PM
showstoppertk
sounds like a bad tranny to me.
Old Feb 16, 2006 | 01:53 PM
nuttyprof's Avatar
nuttyprof
the problem lies in proving it to the dealers. by the time you get there, your car is warmed up and the grinding stops...
Old Feb 16, 2006 | 02:06 PM
showstoppertk
so true.
Old Feb 16, 2006 | 02:32 PM
Thanks a lot
Isn't the drive train warranty 60,000 mile or 60 months?
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
