just ordered a crank pully do i need it's belt?
Old Mar 2, 2006 | 05:56 AM
MEI's Avatar
MEI
Default just ordered a crank pully do i need it's belt?
guys i just ordered a UR crank pully do i have to oreder a special belt or can i use the one i have in my car?
Old Mar 2, 2006 | 06:02 AM
jpc350z's Avatar
jpc350z
It's a smaller diameter than stock.. You'll need a smaller belt.. Doesn't it come with the pulley?
Old Mar 2, 2006 | 06:18 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
You need to order the Gates belts. Don go with any other/cheaper belts!
Old Mar 2, 2006 | 07:29 AM
first350's Avatar
first350
I think UR only makes a under-drive pulley for the 350Z (I just ordered mine too!)...which means you'll need a new belt
Old Mar 2, 2006 | 07:52 AM
MEI's Avatar
MEI
i looked into some websites and they have only the coplete set and i just ordered the crank pully so do i have to go for the belt set?
another thing can you post a link for a good website sells those parts?
Old Mar 2, 2006 | 08:08 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Yes get the complete (2 belts) set. The Gates belts are a lot stronger as well and just a better belt. http://performancenissanparts.com/ca...roducts_id=351
Old Mar 2, 2006 | 09:32 AM
first350's Avatar
first350
I'm fairly sure that the same belt is used for the UR under-drive crank pulley and the complete set...the under-drive portion is done just on the crank - the other pulleys are lightier, but same diameter. (the under-drive part is what changes the diamater and thus requires a different size belt.)
Old Mar 3, 2006 | 06:41 AM
MEI's Avatar
MEI
so you are saying i can run the crank pully with the existing belt i have on my car
Old Mar 3, 2006 | 09:43 AM
spacemn_spiff's Avatar
spacemn_spiff
Why did they make it smaller diameter than stock?
Old Mar 3, 2006 | 09:58 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Its lighter as well but to spin faster.
Old Mar 3, 2006 | 10:51 AM
Dubai's Avatar
Dubai
Here's gates' belts size that you need;
Gates Micro-V K060445 ( 21mm x 1150mm O.C.) and Gates Micro-V K040353 ( 14mm x 910mm O.C.)
Old Mar 3, 2006 | 11:24 AM
jpc350z's Avatar
jpc350z
The pulley is an underdrive meaning it does not drive the accessory's that run off it as it would at the stock pulley's rpm...Running accessories at a lower rpm reduces Tq needed to drive them allowing more engine tq. to the wheels...The lower accessory's rpm seems not to be a problem since many of these pulleys are on ZZZZZ'S. The new belt is needed to fit the diameter of the u\r pulley groove...As has been pointed out it's also lighter where most of it's benefit comes into play..
Old Mar 3, 2006 | 02:18 PM
first350's Avatar
first350
No - you DO need a new belt if you have an under -drive cran pulley. (What I was trying to say was that both the UR pulley SET and just the UR crank pulley require the same belts - which are different than stock)
sorry for the confusion.
Old Mar 5, 2006 | 10:19 AM
Dissolved's Avatar
Dissolved
Go with gatorbacks. I've used OEMs and Gates. All squealed on me. Gatorbacks are supposed to be one of the only ones that don't do this. I can find the part number later, or pm Rhoads
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
