crank key
Old Mar 26, 2006 | 01:08 PM
jcarp's Avatar
jcarp
Default crank key
found out today that some how my crak key broke off. i've got a new one coming in and i was wondering if you can just tap it back in or you have to take the sprocket off then put the key on and the sprocket back on. hopefully i can just put the key back on but imput on this would help.
Old Mar 27, 2006 | 04:38 AM
johnlotusboy's Avatar
johnlotusboy
And your bent valves will still need the heads off and a lot of other stuff. to
fix.
The crank key is just the tip of the damage.
Old Mar 27, 2006 | 04:41 AM
jcarp's Avatar
jcarp
dont know yet if the valves are bent bc it was only at idle when it happned. i'm gonna try to press the key back in when i get it back. if the valves are bent i'm gonna to a total rebuild when i get the motor down.
Old Mar 27, 2006 | 04:51 AM
johnlotusboy
If it's the crank key and you didn't do pulley work then Nissan has a warranty you can argue with.
Old Mar 27, 2006 | 05:02 AM
jcarp's Avatar
jcarp
yeah i can take them to court and prove my side but that could take 2 years and i just want my car back. i've already got the dealership on the local news for screwing customers and they tried to make it look like i was in th fault but they havent replied my bbb complaint.
Old May 12, 2022 | 11:52 AM
sincityvqlife's Avatar
sincityvqlife
hey did you ever find out if your valves were bent ? Same exact thing happened to me .
Old May 12, 2022 | 01:09 PM
travlee's Avatar
travlee
Master
Last login from Him was 16 years ago. Don't Hold breath on him answering
MDTour
Aug 21, 2018 09:09 AM
1000gixxer
Feb 7, 2012 06:29 PM
CaliSilvZ
Northern California
Oct 19, 2009 09:02 PM
Mazinger Z
May 8, 2008 10:32 PM
JETPILOT
Jan 28, 2007 10:21 PM
