Engine cooling problem????`
Just wondering what you guys might think this is? My car runs awesome now but for some reason after like driving it really hard, itll start to overheat. Like i can actually see the gauge go from the normal temp all the way to hot. Then when i go to burp the system its all air. What is causing the system to get air in it everytime I run the car hard? If i drive normal it NEVER happens.
i have turbonetics turbo kit, jic catback, kinetix SSV, aam fuel return, 550cc injectors, stock radiator, nismo thermostat and a few other things but not related to the motor
I have a PE radiator, greddy breather tank, and nismo low temp thermostat and I experience this as well. Is your overflow tank boiling over?some are speculating that it is head lift. how many psi are you boosting?
check out this thread.
https://my350z.com/forum/forced-induction/178494-headlift-sleeved-and-non-sleeved-engines.html
Originally Posted by Gman2004
welcome to the repeated abuse overheating club.
https://my350z.com/forum/showthread.php?t=178494
Originally Posted by G35cTT
I'm having the over heating and boiling over problem after driving hard also, I have a fully built engine using the GReddy breathere tank, APS oil pan and engine oil cooler. Running 1.3bar. I was told it's from running the oem bumper which isn't allowing adequate air flow to the radiator. You think a different bumper will fix this or is this something more?
I am still overheating. Either our cooling system is not adequate for our set up or we have headlift. I was overheating ocassionally and this last week it was getting worse. Today I checked the water and it was low. After filling it up the car doesn't overheat on low boost 5.5psi.....haven't tried 10psi yet. The missing waster/coolant probably spewed out of my overflow tank. Try toping off your cooling system and see if it gets better. For now I am staying out of high boost (16psi) and will no longer still at WOT for more than 15 seconds.
I have everything you have plus a Top Secret front bumper with a big hole in the middle. Look at my avatar.
Right I do top it off and I'm good to go, I'm running about 18psi and haven't tried going lower as this happens. I pray to god it's not headlift? The engine still runs if you have headlift?
