Strut bar moved!.
Old May 9, 2006 | 04:01 PM
Default Strut bar moved!.
After installing the plenum spacer, I installed the strut brace, and torqued all the bolts. About 2 weeks later you can see that the strut mounting bracket has shifted. Note the dirt where the bolts used to be.
With the spacers in place, there is little surface tension between the mounting bracket and sheet metal. The bracket rests on just 4 spacers. I checked the bolts and they are tight. Since the strut brace clears the plenum and hood, I’m going to leave well enough alone.
Old May 9, 2006 | 04:25 PM
Pats300zx's Avatar
Pats300zx
ECZA-President
David..
What did you torque the bolts to???
Old May 9, 2006 | 05:17 PM
Originally Posted by Pats300zx
David..
Sorry but I cant remember. I had a torque chart with bolt size, and used the recommended torque numbers.
Old May 9, 2006 | 05:57 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
those are not factory bolts I assume. As you raise the bar, I would recommend increasing the tension of the bar itself (essentially shortening it by the amount you raised it)
Old May 9, 2006 | 06:01 PM
05-Z's Avatar
05-Z
Interesting....so I suppose the brace is doing its job?
Old May 9, 2006 | 06:06 PM
Z1 Performance
Former Sponsor
if the brace moved it's not doing it's job at all actually
Old May 9, 2006 | 07:10 PM
I adjusted the bar so that it clears the plenum. That puts a lot of stress on the end brackets and bolts (which came with the spacer). I’m concerned that the spacers are not as strong as the bolts. In other words, if I tighten the bolts, will the spacer crack.
Old May 9, 2006 | 07:19 PM
Z1 Performance
Former Sponsor
I did not say to tighten the bolts...those bolts actually do not even get tightened very much at all (maybe 15-20 ft lbs?). What you need to do is tighten the brace itself - it is adjustable. How long are those bolts relative to stock?
Old May 9, 2006 | 07:24 PM
Alberto's Avatar
Alberto
Cranky FI Owner
+1 on adjusting the brace, put some load on it...iirc its a 7/8 or 1" wrench, or just use an adjustable wrench David.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
