Dyno with auto trans
Old May 15, 2006 | 07:32 PM
2003G35's Avatar
2003G35
Question Dyno with auto trans
I did a search and could not find how to keep trans in 4th gear and not down shift at low RPM? I know this was talked about a long time ago.
Old May 15, 2006 | 08:13 PM
dscheers's Avatar
dscheers
USE THE MANUAL !
Old May 16, 2006 | 03:45 AM
2003G35's Avatar
2003G35
Originally Posted by dscheers
USE THE MANUAL !
I assume you mean run the trans in manual mode, this does not keep it from down shifting below 3800 RPM.
Old May 16, 2006 | 05:19 AM
booger's Avatar
booger
If you dyno on a load base dyno . You can run it in third . You can get to WOT by 3200rpm with out it down shifting . We do use manual , but it will still down shift
Old May 16, 2006 | 08:51 AM
dscheers's Avatar
dscheers
Mine never downshifts at WOT
You must be doing something else than a standard DYNO run, I'm lost...
Danny
Old May 17, 2006 | 04:35 AM
booger's Avatar
booger
Danny
Try putting the car in third and get the rpm's at around 1500 to 2000rpm's . Then floor it without hesitation....it will down shift . If it doesnt..there is some thing wrong.
Old May 17, 2006 | 08:55 AM
dscheers's Avatar
dscheers
In automatic it does immediately, but if I'm in manual, it doesn't...
Danny
Old May 17, 2006 | 10:00 AM
LODOSS's Avatar
LODOSS
try it first, i know it does that on many other manual-auto cars..
Old May 17, 2006 | 10:04 AM
roneski's Avatar
roneski
Mine doesn't downshift at WOT. But there are several different versions of the tranny programming for different years.
Old May 17, 2006 | 10:37 AM
dscheers's Avatar
dscheers
I dyno my car like that, so I know for sure it doesn't...
Maybe it has something to do with the different Valvebodies ....
Old May 17, 2006 | 05:01 PM
2003G35's Avatar
2003G35
I had my trans program re-done by dealer and old and new program cause it to down shift at low RPM in manual. I was not able to tune below 3500 before which made car slugish of the line. I have the E-manage ultimate now and want the best tune I can get!
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
