B-Line oil cooler kit... anybody have any experience?
Old May 16, 2006 | 10:00 AM
geez zee's Avatar
geez zee
Question B-Line oil cooler kit... anybody have any experience?
Good day!
Does anyone in this group have any experience with this particular B-Line oil cooler kit?
http://www.blinemotorsports.com/oilcool.html
If so, I would greatly appreciate your comments and evaluation.
Thanks,
Rob
Old May 16, 2006 | 12:13 PM
JasonZ-YA's Avatar
JasonZ-YA
i am installing one from summit. im buying evrything separate.
core- $60 bucks
sandwich - $70
lines & fittings ?
should be much less.
Old May 16, 2006 | 01:40 PM
350Zteve's Avatar
350Zteve
Rob,
Are you mechanically inclined? If so, I recommend building your own kit. The cooler in this kit looks a little small in width. It also looks like it uses -8 lines. You should run -10 lines. Do a search under my user name and you will find a write up I did on my oil cooler install.
Old May 16, 2006 | 02:50 PM
zachcrosen's Avatar
zachcrosen
core- $60 bucks
sandwich - $70
lines & fittings ?
Are you going with the B&M core? I saw it on Summits website. I already have a sandwich adapter and it has two extra 1/8 NPT threaded holes in it already. I have thought about getting an oil cooler because I have noticed my oil temps stay around 200-220 deg. and have hit 240+ degrees when under heavy throttle. I do have the Vortech SC which gets its oil from the engine and I am assuming that is part of the reason my temps are high.
Old May 16, 2006 | 04:19 PM
JasonZ-YA's Avatar
JasonZ-YA
Yup!
Thats the one! i have a sandwich that has -8 AN. i think those 1/8 are too small though!
-Jason
Old May 18, 2006 | 03:21 PM
geez zee's Avatar
geez zee
Originally Posted by 350Zteve
Rob,
Zteve, I checked out you oil cooler install thread... great job! My thinking is that I will probably follow your lead and create my own.
Did you support the oil cooler core at both the top and bottom?
As I recall, you are using the Earl's core... any particular reason for your choice? There seem to be several similar out there on the marget.
Thanks for the great info!
Rob
Old May 18, 2006 | 03:32 PM
350Zteve's Avatar
350Zteve
Rob,
I did not support the bottom. When I finished the install, i saw that everything fit nice and rigid, so I did not feel any bottom supports were needed.
I chose the Earl's cooler because I've used them on other cars in the past with great success. I have also used Mocal and Setrab, all of which are excellent. Don't waste your time with a cheap unit like B&M, they do not cool as well (I've used those too and have first had experience with their inferiority). Spend the money for an Earls or Setrab core. I've done over a dozen oil cooler installs and these are the best cores.
Let me know if you have any questions as you go through the install process.
Rob
Old May 18, 2006 | 03:52 PM
geez zee's Avatar
geez zee
Thank you very much, Zteve, for sharing your experience and insight! I'm sure that I will be asking some more questions before I finally get this done. It seems that I go through an awful lot of foreplay before I ever actually get anything done... heck, my Stoptech kit sat in the garage for a full six months before I got around to installing it.
I thought that retirement meant that I would have more time to do neat stuff... 'taint so!
Happy-nearly-the-weekend!
Rob
Old May 18, 2006 | 04:50 PM
JDMFairlady21's Avatar
JDMFairlady21
wow good stuff to know... could youpost a link to that how-to write up? tia
Old May 18, 2006 | 05:08 PM
beastie's Avatar
beastie
I looked up the oil coolers you mentioned here. Which exact model of Earl's would you recommend? I noticed a big difference in price between the small and large row models. Also, did you need to buy anything else to install them correctly?
Thanks
Old May 18, 2006 | 05:12 PM
Philthy's Avatar
Philthy
Boost Junkie
Looks like they're building a new Intake Manifold for the Z too...
http://www.blinemotorsports.com/products.html
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
