350z Timing Belt Question
Old May 22, 2006 | 02:50 PM
rightwinger's Avatar
rightwinger
Default 350z Timing Belt Question
Hi,
I am about to buy a 2003 Nissan 350z with 50k miles. The guy has not changed water pump/timing belt yet. Is this something I need to worry about, and how often do the belts on the 350z last?
Please let me know as soon as possible
Thanks
Tom
Old May 22, 2006 | 03:19 PM
rightwinger
Please help me out
Old May 22, 2006 | 03:22 PM
EM-EFER's Avatar
EM-EFER
Its a timing chain... not a belt and it doesnt need to be changed until 100k-125k
Old May 23, 2006 | 01:35 PM
Eazzy's Avatar
Eazzy
Rightwinger ---dont be afraid to ask questions --Thats what we are all here for ,,,although searches do come in handy
Old Nov 13, 2006 | 05:07 PM
mikealexander's Avatar
mikealexander
You Will Break The Gears Before The Chain Busts
Old Nov 13, 2006 | 05:10 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Timing chains do not require maintenance on the newer nissans. Well at least in the eyes of nissan when you take their tests.
Old Nov 13, 2006 | 06:23 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Its a chain...
Old Nov 13, 2006 | 07:33 PM
EM-EFER's Avatar
EM-EFER
That is not true.. I had 10 stress cracks on my chain when my car had only 30K miles. I ordered a new one from performancenissan while I was rebuilding. But who knows why that is .. I also had a cracked tensioner to.
Old Nov 13, 2006 | 07:49 PM
rocks's Avatar
rocks
Timing belt / waterpump on my porsche had to be changed every 30k miles to be safe. bad things would happen if it broke. You dont want to know the rebuild costs on a porsche v8.
Old Nov 13, 2006 | 07:55 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Let's get the facts straight: the 350Z VQ35DE has a timing chain that should last the life of the engine (or until you rebuild it). There are two engine drive belts (one for the PS/ancillary drives and the other for A/C) and they should be replaced at 60K, if not sooner.
Old Nov 14, 2006 | 04:48 AM
MasterRacer's Avatar
MasterRacer
Yep what he said Chains usually run the life of the car the other belts
need to be checked once in a while for cracks and stuff. Read the owners manual and it should tell you when to check what
Old Nov 14, 2006 | 05:03 AM
Eazzy's Avatar
Eazzy
Chains last a long time but they do stretch (Actually, wear, so they become longer) and gears wear also. Its a given to replace on a rebuild and Id say, Just cuz at around 100,000 +. What happens is it knocks the Crank/Cam timeing out of sync.
Old Nov 14, 2006 | 07:55 AM
97supratt's Avatar
97supratt
Does anybody know if our engines are interference engines or non-interference engines? If in some rare instance the timing chain does break, it would be helpful to know if our valves will get bent.
Old Nov 14, 2006 | 08:03 AM
Eazzy's Avatar
Eazzy
I havent a clue, But I would say they were interference
Old Nov 14, 2006 | 08:47 AM
97supratt's Avatar
97supratt
Why would you say that? There are much higher compression vehicles that aren't interference engines like all the older B-series honda engines.
I'm just curious I guess.
Old Nov 14, 2006 | 10:13 AM
Eazzy's Avatar
Eazzy
Im saying that because i dont know weather a valve may stay open if the chain breaks and hit a piston on its way to TDC
Old Nov 14, 2006 | 12:53 PM
Q45tech's Avatar
Q45tech
interference engine
I still have as built chains on my 311,000 mile Q engine [new metal guides at 100k] the chains have stretched < 4 degrees relative to crank......nice upper rpm boost above 6,000 thru 7300 rpm and the VVT retard stops the lope one would expect at idle from a domestic with such high mileage.
Unfortunately on the newer 3.5 and 4.5 there is no way to adjust initial to compensate for stretch so maybe replace chains every 150k........whenever the idle gets a little shakey.
With a seperate crank and cam sensor the ecu might throw a code when things get too far out of whack. We'll have to wait a few more years to find out.
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
NYGiants0186
Sep 8, 2015 10:37 AM
