to all diy guys
Old Jun 8, 2006 | 09:35 PM
cleanandquick06's Avatar
cleanandquick06
Default to all diy guys
ok, im doing a few mods 2maro and i need some specs. ok, what should i torque the 02 sensors on the test pipes? and im doing a pulley kit from ur 2maro. the 3 pulley kit. i know the crank pulley is torqued to about 34 inch lbs, but what about the ac and the alternator pulleys? any help would be awesome.
Old Jun 9, 2006 | 02:38 AM
overZealous1's Avatar
overZealous1
do you have a socket to be able to read the torque on the 02's? do 40 and you will be fine.
now, who told you the crank pulley was at 34 in lbs? setting range is 90"ft" lbs. will take alot more than that to get it off.
Old Jun 9, 2006 | 02:57 AM
SpeedRcr's Avatar
SpeedRcr
make sure to put some antiseize on the threads...save you hassles later if you have to take them off...i spent a good 30 minutes recutting the threads with a dremmel
Old Jun 9, 2006 | 05:56 AM
cleanandquick06
im sorry, not inch lbs, but i got my setting from the ur instructions. it says to torque to 29-36 ft lbs
Old Jun 9, 2006 | 06:13 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
still not enough torque. Think it somewhere just over 100ft-lb. Google for the instrutctions for the KJR pulley (same sizes as oem, just lighter). i believe it says to 45ft-lb plus 60 degress or something to that matter.
Old Jun 13, 2006 | 04:16 AM
omernazeer84's Avatar
omernazeer84
so exactly how much FT/Lbs should i do for the UR?
over 100 or 29-36?
Old Jun 13, 2006 | 06:49 AM
SGP-BFH's Avatar
SGP-BFH
Your just not going to be able to torque everything to spec. If you think about it, just about every nut or bolt on the car will have a torque spec. But are you really going to be able to torque down an alternator pulley? Not unless you have some way of holding it still really tight. The 02's you can just put a little anti-sieze on and just get it nice and snug with a 7/8 or 22mm wrench. On a crank pulley you can hold the engine still with a flywheel holder but then the tranny has to be out. Get yourself an Impact Gun.
Old Jun 13, 2006 | 09:30 AM
cleanandquick06
ok, i torqued to 110 ft lbs and its working awesome, thanx
Obadabot
Jun 18, 2023 11:31 PM
Alexreyes
Sep 30, 2015 11:30 PM
