3.5 Final Drive Question!!!!!!
ok i have a g35 but it seems that a lot of people on this fourm talk about the final drive more....some quick questions that i tried searching for
1.i have a 5at 3.3FD with no LSD so in order to switch to a 3.5 do i need LSD???
2. what are the exact parts i need to buy in order to put a 3.5 FD in?? cant i just get the ring and pinon from 350evo.com for 400$ and put it in??
3. also im in houston and does anyone know a good shop that could instal it??
thanks guys if you can help on this info....im still new to all this stuff
There's no way to easily convert the internals from the 3.3 to the 3.5. Your best bets are to trade with somebody who has the 3.5 already and is looking for the 3.3, find one off a junked 350Z/G35 or purchase a new pumpkin.
Once you have sourced a 3.5 pumpkin, you can add or replace the LSD if it is an open differential or has the VLSD, otherwise just swap the pumpkins. Any reputable shop can do a pumpkin swap, that's the simple part.
Performance Nissan
Performance Nissan
its almost cheaper to find someone with a 3.5 MT who wants a 3.3 rear end... they will most likely swap rear ends with you...
or find a 3.5 rear end off a manual Z / G from a junk yard
a NEW complete assembly ready to swap WITH lsd will be $1250 plus shipping...
gearing alone in 3.5 is around $500.. you WILL need a VLSD or Open Differential from a 3.5... To purchase that new, you are looking at more then $1250...
You can also get a 3.7 gear set which works even better on the automatics then the 3.5... for that, find a rear end at a junk yard and put the 3.7 gear set in it...
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
