Is there a way to raise idle for 2004.5 Z ?
Old Jul 25, 2006 | 09:49 PM
mistaboosta's Avatar
mistaboosta
Default Is there a way to raise idle for 2004.5 Z ?
I've tried to get the idle raised via CONSULT II but it seemed not to work on my car, looks like Chiper can't do it either. Wondering if there is any way of doing it? Would using a jack valve on the manifold that will close when the car goes into boost work fine?
Old Jul 26, 2006 | 01:05 AM
Triji's Avatar
Triji
So the UTEC will both raise the idle and the Rev Limiter?
Old Jul 26, 2006 | 03:39 AM
DavesZ#3's Avatar
DavesZ#3
Starting with the 2004 models, the Z became a Ultra Low Emission vehicle. Changes in the ECU made it so the dealer (or anybody else with Consult II) can no longer adjust the idle.
Old Jul 26, 2006 | 03:55 AM
taurran's Avatar
taurran
Sorry... was late when I posted that and was thinking rev limiter for some reason. Anyway, I thought the cypher would do it, and I know the reflash will.
Old Jul 26, 2006 | 05:33 AM
Mike@Altered's Avatar
Mike@Altered
The best way to raise the idle on the 2004.5 350Z & G35 is via an ECU Flash. Here is a link for informtion on our ECU Flash programming: http://www.alteredatmosphere.com/mm5...y_Code=350Z_EM
Hope this helps,
Old Jul 26, 2006 | 06:34 AM
mistaboosta
Mike I've sent u a PM
Old Jul 26, 2006 | 01:43 PM
esfand's Avatar
esfand
other than a reflash, is there any other way?????
Old Jul 26, 2006 | 07:22 PM
psychoticminds1's Avatar
psychoticminds1
ope a small hole in the throttle plate do a search on it i remember a few people doing it
Old Jul 27, 2006 | 12:51 AM
mistaboosta
Hmm, I'll definitely check this.
Old Jul 27, 2006 | 03:34 AM
DavesZ#3's Avatar
DavesZ#3
Yes, you definitely better check into it before you do that. There is a post here about somebody that did it and wound up screwing up the TB.
Old Jul 28, 2006 | 08:12 AM
psychoticminds1
i believe the throttle plate is made of brass so even if you make the opening to big you can always braze (Spelling?) it closed. But in theory all as your doing is changing the minimum amout of air the motor can injest. I know alot of the american guys do it on some of the ls1's
Old Jul 28, 2006 | 08:30 AM
plumpzz's Avatar
plumpzz
PM overzealous1, scott has done that to his car.
Old Jul 28, 2006 | 08:31 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
we drilled a 1/8th inch hole in my TB and i idle perfectly at right under 1000 with the air off.
pretty easy to do
Old Jul 28, 2006 | 10:31 AM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/intake-exhaust/184506-drilled-hole-in-throttle-plate-uh-oh.html
Old Jul 28, 2006 | 11:26 AM
Gman2004's Avatar
Gman2004
Originally Posted by DavesZ#3
post #32 in that same thread.
https://my350z.com/forum/showpost.ph...1&postcount=32
liqalu04
Jan 2, 2022 12:58 PM
black3.5z
Oct 20, 2015 05:50 PM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
