Manual Says Radiator Cap supposed to be replaced?
Old Aug 31, 2006 | 01:03 PM
boma's Avatar
boma
Default Manual Says Radiator Cap supposed to be replaced?
Why? I have a Honda Civic and the manual never required the changing of the radiator cap. Do I really need to, because I have better things to spend $30 on.
Old Aug 31, 2006 | 01:48 PM
I checked and found the recommendation in the 60,000 mile/48 month premium maintenance schedule. Sounds like wise idea to prevent overheating. I can afford $30 every 60,000 miles.
Old Aug 31, 2006 | 01:58 PM
Silkk's Avatar
Silkk
I replaced mine with the Nismo cap. Not sure what good it does, but I'm at 76,000 miles and I've never once came near overheating. Stays nice and cool.
Old Aug 31, 2006 | 02:02 PM
roast's Avatar
roast
Nissans "premium" maintenance schedule recommends replacing it every 30k miles.
A little info on radiator caps...
http://www.womanmotorist.com/index.p...524/event=view
Old Aug 31, 2006 | 02:14 PM
The Brickyard Rat's Avatar
The Brickyard Rat
For 30 bucks I'll take the word of the manual
Old Aug 31, 2006 | 02:24 PM
Oooops. Then I forgot to replace mine at 30,000 miles. Guess I will catch it at 60,000 miles.
Old Aug 31, 2006 | 02:33 PM
Eazzy's Avatar
Eazzy
The Cap holds pressure that in turn raises the boiling point of ur coolant depending on how much its rated at in PSI. Cap gets old,---Rubber seal on Cap loses it ability to hold pressure. Thats why u replace the Cap. Its not the end of the world but its a good idea to replace it every so often.
Old Aug 31, 2006 | 03:54 PM
bailey bill's Avatar
bailey bill
If you don't want to pay the costs associated with the Premium Maintenance Schedule, don't follow it! I don't. (And I'm an engineer that spent 30 years in machinery maintenance.)
The so-called Premium Maintenance Schedule is just a profit-maker for the service department.
bill
Old Aug 31, 2006 | 03:58 PM
roast's Avatar
roast
It just depends on if you're the type that would rather wait for a belt to break or a hose to spring a leak or a dead battery to leave you stranded rather than preventing it with pre-emptive maintenance.
Like Eazy said... "it's not the end of the world, but it's a good idea to replace every so often."
Old Aug 31, 2006 | 05:04 PM
DavesZ#3's Avatar
DavesZ#3
After several years of use, the spring in the cap will weaken and it won't hold the full pressure anymore. The rubber seal will deteriorate and leak. That will lead to overheating. Think about the conditions that the radiator cap is exposed to every day you drive the car.
It's probably not a bad idea to replace it, but first have them test the radiator cap.
Attached Thumbnails Manual Says Radiator Cap supposed to be replaced?-snap.jpg
350z82
Oct 1, 2015 06:25 PM
