Accidently reved redline while rolling
Old Sep 21, 2006 | 07:24 PM
Changvi's Avatar
Changvi
Default Accidently reved redline while rolling
Did i do any damage to my engine? I was in neutral at about 5 miles per hour, some punk reved at me, so i reved back. As i reved, the rpm hit 6500rpm and the shift light came on for about one second then it went down. Any input would be appreciated.
P.S:I've never reved my car till redline before.
Old Sep 21, 2006 | 07:27 PM
Zexy's Avatar
Zexy
You'll be fine.
USMC-Z's Avatar
USMC-Z
Z Veteran
Nothings wrong with hitting redline. I do it all the time when I race. Even if you go past the rev limiter, I doubt you would do any damage unless you were in that zone for a while. Just to let you know, going past the rev limiter will cut off the fuel which will cause your car to be running lean.
Old Sep 21, 2006 | 07:30 PM
zz350zz's Avatar
zz350zz
Umm....if you hit the redline without any new ecu or piggyback that has disengaged the rev limiter....then in no way can you go "past" it unless you downshift to a wrong gear.
I bounce mine all the time and it's still runnin strong
EDIT: the point of a rev limiter is to prevent damage
Old Sep 21, 2006 | 08:42 PM
Mazinger Z's Avatar
Mazinger Z
Oh no! Call the press!
Old Sep 21, 2006 | 08:57 PM
Armitage's Avatar
Armitage
You'll be fine.
You should only worry if:
A) You do that ALL The time. (More wear and tear)
B) You accidently downshift to a lower gear when trying to upshift and you hit like 9000RPM's.
Old Sep 21, 2006 | 09:46 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The redline / rev limiter is set where it is for safety.
If 6600rpm was unsafe, the redline would have been set lower.
Old Sep 21, 2006 | 09:53 PM
Acree's Avatar
Acree
Dude don't do that! You will blow you're engine!
-Acree
Old Sep 21, 2006 | 10:53 PM
Mazinger Z's Avatar
Mazinger Z
lol, did the person in the other car start cracking up?
Old Sep 22, 2006 | 05:37 AM
Alberto's Avatar
Alberto
Cranky FI Owner
One more time and its BOOM!
Obadabot
Jun 18, 2023 11:31 PM
apex locator
Jul 23, 2021 02:27 AM
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
Mattg350z
Oct 2, 2015 06:51 AM
