VQ40DE revability
Old Oct 20, 2006 | 10:36 PM
JClaw's Avatar
JClaw
Default VQ40DE revability
I'm looking into possibly building a VQ40 block/VQ35 heads N/A motor for my '89 S13. I know the new VQ35HR is somewhat based on the new tall deck VQ40 block design and I've been told the 4.0L bottom end is very strong.
Since it's a stroker motor I'm worried about reving it too high. I believe the stock redline on the '05 Frontier is 6000 rpm.
So in short how high can I safely rev the 100% stock VQ40 shortblock? If I follow through I'm thinking of setting the rev limiter at 6500 rpms since this is a daily driver. Thoughts?
Old Oct 21, 2006 | 06:44 AM
chimmike's Avatar
chimmike
the 40 is a longer stroke with a taller deck than the 35 IIRC so revving it won't be as free as even a regular vq35.
besides, with the right valvetrain and rods, a vq35 can be revved to 8000 or so.
Old Oct 21, 2006 | 09:13 AM
kaybee650's Avatar
kaybee650
my xterra has the 4.0 and the rev limiter is set to 6200k ... but thats all i can tell you about that. no plans on modding it.
Old Oct 21, 2006 | 09:27 AM
JClaw's Avatar
JClaw
Ok I guess if it's 6200 stock 6500 shouldn't push it too much. If I go with the new tall deck design I could either go with the VQ40 block or VQ35HR block. 6500 rpm vs 7500 rpm. Torque vs Revs. I could use a complete VQ35HR, throw 4.636 gears into my R200 and rev the **** out of it... still debating.
Old Oct 21, 2006 | 07:23 PM
1G-350Z's Avatar
1G-350Z
JClaw
Our shop at one point look into doing a VQ40.... It's not a VQ35 stroked out. The parts are not interchabgable. heads might fit. but you might get piston slap not sure. The rods are the type as the VQ35. so I'm sot sure it will be stronger... Not sure what your overall goal is by doing a motor swap. You will be limited in the aftermarket. with a VQ40. If you are looking for RPM's for your S13. Cams some Head porting, NISMO Oil Pump is a must. And obvioulsy tuning... We have motor pkg's coming soon.
Old Oct 21, 2006 | 10:03 PM
Z350Lover's Avatar
Z350Lover
yup.... I am running carrillo rods and ferrea valvetrain set... and meeting 8200rpm is no problem for my car...
cheers,
richie
Old Oct 21, 2006 | 10:20 PM
JClaw's Avatar
JClaw
Originally Posted by 1G-350Z
JClaw
Ok thanks. I think at this point it would be smarter to wait somewhat and get the VQ35HR, for factory reliability.
Old Oct 21, 2006 | 10:31 PM
1G-350Z's Avatar
1G-350Z
On our mustang Dyno, the 2003's give us the highest stock baseline... Over all the motors so far.
athensgls
Nov 24, 2009 03:59 PM
G35_Guy
Sep 9, 2009 02:48 PM
07_350z_JP
Nov 21, 2008 04:01 PM
fito
Nov 3, 2005 08:18 AM
