help with gas analysis
Old Oct 23, 2006 | 01:35 PM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Default help with gas analysis
Hey guys, I had to run a gas analysis for my lab in AET class. I knew I was running rich because I was getting black crap on my exhaust tip and getting pretty poor gas mileage. I ran the test this afternoon and im alittle confused by the readings.
Idle:
HC-309 CO-3.68 O2-.43 CO2-12.4 NOx-113
2500prm:
HC-126 CO-.66 O2-.73 CO2-13.9 NOx-325
Why am I running so rich at idle? Why does my NOx go so high at 2500 RPM?
Old Oct 23, 2006 | 01:42 PM
plumpzz's Avatar
plumpzz
If you run leaner (like at 2500 rpm)you tend to get a more complete reaction. Hence the more NOx
Whats the units of those readings? mols/min or cf/min..?
Old Oct 23, 2006 | 01:47 PM
Jim@Showstoppers
after checking my specs again I forgot I wasn't running a cat, which would explain the higher CO.
HC's and NOX are PPM. CO, O2, and CO2 are %.
It looks like im running just a touch rich.
Old Oct 23, 2006 | 02:02 PM
plumpzz's Avatar
plumpzz
I think cat converters don't convert HC's, just CO and NOx to N2 and 02 and CO2, and some sulfurs to safer sulfurs.
2500prm:
From your numbers, you're running quite a bit leaner at idle than at 2500 dont you think? CO is produced mostly in incomplete reactions. Its pretty hard to deduce any real information from just this data without injector pulse and duty cycle as well as throttle position and load.
Old Oct 23, 2006 | 02:06 PM
Jim@Showstoppers
Isn't CO the rich detector? rich is greater then 2% and lean is less then 1%? Im "fairly" new at reading these numbers. I have my pulse and duty cylce somewhere...
Old Oct 23, 2006 | 02:07 PM
plumpzz's Avatar
plumpzz
did you take these measurements on a cold engine? The engien has to be loaded for a few minutes before you can get accurate results from any gas analysis an engine.
Old Oct 23, 2006 | 02:09 PM
plumpzz's Avatar
plumpzz
yes it is, qualitatively, but not quantitatively
Old Oct 23, 2006 | 03:00 PM
97supratt's Avatar
97supratt
High nox is usually the result of no/damaged cats or egr valve not working properly. Always warm up your car to normal operating temps before doing any kind of exhaust readings.
Old Oct 23, 2006 | 03:21 PM
plumpzz's Avatar
plumpzz
NOx is always there without a cat, and is dependant on the amount of fuel burned, since NOx are not in the vapor state in gasoline (not in large amounts).
Old Oct 23, 2006 | 03:25 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Interesting thread, subscribing.
Old Oct 23, 2006 | 03:41 PM
Jim@Showstoppers
I have no cat so that explains the NOx, I had the car warmed up prior to running the tests.
Old Oct 23, 2006 | 03:48 PM
Jim@Showstoppers
just to show what we were doing...
Here's if you fogged your intake with unburnt propane
Idle:
HC-919 CO-12.35 CO2-5.8 NOx-2
2500 RPM:
HC-572 CO-10.31 O2-.79 CO2-7.6 NOx-97
Here's if you create a BIG vaccum leak.
Idle:
HC-418 CO-1.10 O2-9.59 CO2-7.2 NOx-268
2500 RPM:
HC-523 CO-.70 O2-7.54 CO2-8.6 NOx-488
Here's if you unplug a spark plug wire
Idle:
HC-2763 CO-.35 O2-6.58 CO2-9.9 NOx-381
2500 RPM:
HC-3380 CO-2.51 O2-5.77 CO2-9.3 NOx-439
Old Oct 23, 2006 | 03:50 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
HC is hydrocarbons (unburnt fuel) right?
Old Oct 23, 2006 | 03:51 PM
Jim@Showstoppers
correct
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
