rpm signal
Old Oct 25, 2006 | 06:18 PM
MadNismo's Avatar
MadNismo
Default rpm signal
ive searched and search and nothing. im installing nitrous and i need a rpm signal for the window switch. ppl have told me pin number so and so but they gave me 2 pins not sure which one it might be so can somebody tell my where one might be also what colour it is, please... thanks
Old Oct 26, 2006 | 11:06 AM
MadNismo's Avatar
MadNismo
ttt
Old Oct 26, 2006 | 11:38 AM
first350's Avatar
first350
what yr z?
Old Oct 26, 2006 | 11:48 AM
first350's Avatar
first350
for '05:
I used pin #62 (Ign 1), Y/R (Yellow base w/ red stripe)
I picked the wire from the wiring bundle that goes through the bulkhead just behind the battery...I took off some of the plastic protection, tapped the wire, and retaped it.
hope that helps.
-Peter
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
After reviewing the service manual, I don't believe the 350Z has a straight up RPM sensor wire.
It has to be determined by using crankshaft position sensor (pin 13), cam position sensor, or ignition signal (the guy in the post above used ignition signal).
At least this is the case with the EU...
hope this helps
Attached Thumbnails rpm signal-ecm-harness.jpg   rpm signal-crankshaftsensor.jpg
Old Oct 26, 2006 | 01:01 PM
first350's Avatar
first350
I used pin #62 for my dynotune window/TPS siwtch on my nitrous set-up. worked perfect.
-Peter
Old Oct 26, 2006 | 04:19 PM
MadNismo's Avatar
MadNismo
sweet it worked thanks people
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
hardwood66
Sep 8, 2015 04:31 AM
Daniel_dh
Sep 7, 2015 12:56 PM
