What is a "double clutch."
Old Oct 26, 2006 | 04:20 PM
praecurvo's Avatar
praecurvo
Default What is a "double clutch."
And not the verb but the noun.
I think it's twin-disc, right?
But what are the benefits/setbacks of this setup?
Old Oct 26, 2006 | 04:31 PM
rocks's Avatar
rocks
push the clutch in and pull tranny out of gear, then release clutch and press it back in then put tranny in gear. thats called double clutching.
Old Oct 26, 2006 | 04:52 PM
praecurvo's Avatar
praecurvo
yea yea rocks, i got the verb of it.
it's the noun i'm a bit soft on.
Old Oct 26, 2006 | 05:49 PM
Motormouth's Avatar
Motormouth
there is no noun verb as far as I know. but why not try using google? I normally have good luck using that.
Old Oct 26, 2006 | 05:54 PM
praecurvo's Avatar
praecurvo
because motormouth, that's the anti-social thing to do. why not share and share alike and have actual humans in real time answer me. neatto, isn't it?
Old Oct 26, 2006 | 05:56 PM
zz350zz's Avatar
zz350zz
Double-clutch isn't a noun.... unless someone is misusing the term
I've never heard of it.
Old Oct 26, 2006 | 05:57 PM
Motormouth's Avatar
Motormouth
getting accurate information is much better.
any post that includes, or starts with the words "double clutch" is asking for trouble. better to not. when you use google, 9 out of 10 times it brings you to a automotive terminology or explaination site with pictures.
check this ****: 10 seconds :http://en.wikipedia.org/wiki/Double_declutch
the only Noun version of double clutch I found was a Nike shoe product. if that is what you are looking for I suggest www.footlocker.com
stick to autonomous machines for lame questions and leave the social interactions for good ones
Old Oct 26, 2006 | 05:58 PM
rocks's Avatar
rocks
Erm there are acutally double disc clutch setups, if i remember right 928s used them in the GTS models. I found what it is, what i thought. It uses two clutch plates, they used them in the older 928s because there were no aftermarket clutches and they held more power. These clutches if i remember have to be aligned or they will wear out in like 5000 miles, its really not worth using one, unless you cant find a single plate.
Here is a picture of it also, http://www.tpub.com/content/construc.../14273_134.htm
The double-disc clutch is substantially the same as the single disc, except that another driven disc and an intermediate driving plate are added.
Old Oct 26, 2006 | 06:00 PM
zz350zz's Avatar
zz350zz
^^^It's not a "double-clutch" though
Old Oct 26, 2006 | 06:05 PM
Motormouth's Avatar
Motormouth
and it isn't called a double clutch disc clutch. or double disc clutch.
it is a twin plate.
and Audi/VW has a DSG transmission, which again, is still not called a double clutch-clutch.
Old Oct 26, 2006 | 06:20 PM
taurran's Avatar
taurran
Listen to Vin and do what you're told. No questions.
Old Oct 26, 2006 | 06:23 PM
savvy's Avatar
savvy
stop your granny shifting ans start double clutching like you should
Old Oct 26, 2006 | 09:36 PM
rocks's Avatar
rocks
AH yea thats right twindisk, i wanted to put one in my 928 but there was no need. I also didnt feel like checking clutch alignment. But no you do not need a twin disk setup.
Old Oct 26, 2006 | 09:41 PM
3FITTTY's Avatar
3FITTTY
+1
Workshop12
Mar 23, 2020 01:45 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
jlb
Oct 15, 2017 05:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
