06 noise when accelerating
Old Nov 5, 2006 | 09:47 PM
Cho_Z's Avatar
Cho_Z
Question 06 noise when accelerating
hey guys i have a 06 350z with 7,xxx miles on it. Recently my car started to make i guess a rattling noise when im accelerating between 2,500-3,000 rpm and right when i shift. its most audible in 1st, 2nd, and 3rd, and somewhat audible in 4th. Its really noticeable when i drive for the first 10 minutes, and then isnt as loud after. It seems like its coming from the front, maybe tranny? im not sure, if you guys have any ideas i would really appreciate it. thanks
Old Nov 6, 2006 | 08:34 AM
Brocken's Avatar
Brocken
Check your oil.
I know that sounds dumb but my car did the same thing right before I figured out it was consuming oil. When I was about 2.5 quarts low the engine would chatter when cold(first 5-10 min). Almost sounded like a clutch chatter but it would happen with clutch engaged or disengaged. Finally figured out the oil was so low that it was causing engine chatter.
Old Nov 6, 2006 | 08:42 AM
clean's Avatar
clean
My car did that and it was one of my cats.
Old Nov 6, 2006 | 09:00 AM
LeMansZ33's Avatar
LeMansZ33
my 06 did that too and it was consuming oil. now they are replacing the whole Effin engine, it only has 10k miles on it. at least its under warranty still.
Old Nov 6, 2006 | 09:56 AM
Cho_Z's Avatar
Cho_Z
ok thanks guys ill give that a look
Old Nov 6, 2006 | 10:54 AM
Mike@Altered's Avatar
Mike@Altered
What octane gas are you using, we've seen a handful of 06's that are pinging between 2-3K rpm.
Old Nov 6, 2006 | 01:11 PM
Cho_Z's Avatar
Cho_Z
i always use premium 91 octane at chevron, can you tell me what a gas ping sounds like?. im going to see if its the oil. give it an oil change see if that helps. i noticed the oil pressure levels are lower than usual so that could be it and i am due for one. thanks for the input guys
Old Nov 6, 2006 | 01:17 PM
quint1's Avatar
quint1
My noise disappears with octane booster.
Old Nov 6, 2006 | 01:25 PM
Mike@Altered
If anyone here is local (in the MD, PA, DC, VA) area and has this problem on their 05' or 06' rev-up, let me know.
deviljon's Avatar
deviljon
i just had this problem a week ago. saw my oil pressure was low so i added 2 quarts and the sound went away.
Old Nov 6, 2006 | 09:48 PM
Cho_Z's Avatar
Cho_Z
i dropped it off at the dealer today to be on the safe side, ill let you guys know whats the culprit once i find out
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
