RevUp Oil Consumption TSB and discussion
well this tsb sucks for me....because according to it, my v2 that i thought was working out for me, meets its "NO GOOD" area on its graph =(
its been 2200 miles and im past half.
if this is their stipulations for whats an OCing revup....then their "real" revised revup must be perfect. but i really hope i dont have to get a v3 cuz ill cry.
I have the v2 and got it by going through the process and filing the final repair attempt paperwork.
Since this is their final repair attempt, then a No Good reading gives me a ton of power for a replacement vehicle.
The dealer also insisted that it was full when I went in (not sure what they did, but I saw it and it was at the H). Well, 1300 miles later, I am down 15mm. The only real issue is getting an honest reading out of a dealer. That can easily be taken care of with a camera.
I'm having another oil consumption test right now. I took it this morning and will be bringing it back after another 1,000 miles.
Originally Posted by cruZin163
I also just got my V2. It's been 1,000 miles and when I checked my oil level it was half way already.
Why has this thread been un-stickied? Will a mod please revert it into a sticky? Having the TSB as a sticky is great but this thread is about a lot more than that. I have found other users' experiences and tips very beneficial.
Originally Posted by cheshirecat79
I may be wrong, but I believe that some oil consumption during break-in is normal.
Hi Guys / Gals. I thought it might be helpful to some folks if the "Allowed Oil Consumption" was mapped proportionally to the "DipStick". So I drew this up in Visio...
^ very nice...
Agree about keeping this thread as a sticky.
Three reasons I feel it's still important:
1- Us G ppl haven't received this OC TSB win.
2- This thread has a running update with the success rate of the V2 that ZeeForce has so diligently kept going from members updates.
3- Is there or will there be a V3 released at a later date.
Administrators/Moderators...please reconsider.
well done mate!
_________________________________
www.my350z.info
@gothchick:
I think there is a little mistake in your calculation:
1/4 th of the dipstick is not 0.25 qt
half of dipstick ist not 0.5 qt
3/4 of dipstick is not 0.75 qt
The oil consumption chart allows 1 qt per 3750 miles.
The oil consumption chart allows 0.133 qt per 500 miles.
Your dipstick refers to the 8 intervals, after 1st the maximum allowed consumption is about 0.133 qt (2mm), after 2nd interval the allowed consumption is about 0.266 qt (6mm), after 3rd it´s about 0.399 qt (8mm) and so on...
Regards
Mike
www.my350z.info
Regards
Mike
www.my350z.info
I took my 2003 G35 in today, and it was 3 quarts low in 1000 miles. They tried to tell me to take it in for a FOURTH time, but I said 3 1000 mile tests is enough. First one = 2 quarts low. Second = 1.5 quarts low. They want me to bring in the receipts of the service records. Fortunately the service has been done at Infiniti/Nissan dealerships.
Are you guys sure the hashed area on the dipstick isn't (1) quart? I always thought it was...
Originally Posted by ZeeForce
Guys I have personally confirmed the question a lot of have posted up on, including myself.
Q: How much oil loss is there between the H” & L” cross hatch marks on the dipstick.
A: 1 quart
Confirmation: Today I had the dealer change the oil on my 05 SS (same oil capacity -5 qt as the 06). I was able to stand next to the car the entire time and we poured in 3 quarts and it did not even register on the dipstick. Poured the 4th quart in and it registered on the last cross hatch mark at the bottom of the “L”. I was also informed that all manufactures (Ford, Toyota, GMC etc) all use the same standards on the dipstick as to the amount of oil low which is 1 quart. It’s an industry standard within the manufactures to all keep their “L & H” marks on the dipstick to be the same.
Oh, and we did crank the engine after 3 qrts were poured in, to get oil into the oil filter. Then we poured the fourth quart in and let it sit for 20-30 minutes, checked the hash mark at it was spot on the 24 mm mark (bottom cross hatch mark).
A: 1 quart
My Z burns exactly one quart every 1000 miles. So at that point, when I check the dipstick, it is at exactly half. I add a quart and it comes to exactly the H mark. Never fails.
Dipsticks are not meant to be linear.
