RevUp Oil Consumption TSB and discussion
Old Jul 7, 2008 | 04:12 PM
  #3241
cheshirecat79's Avatar
cheshirecat79
Originally Posted by mgnchakar
anyone notice the v2's redline is at 6500 instead of 7k? Mine is like that; engine revs stop at 6500 for me
wtf? first ive heard of this
Old Jul 7, 2008 | 05:32 PM
  #3242
hbenet's Avatar
hbenet
I am about to get my engine replaced. However now this post ^ has made me wonder. Could any one be so kind to confirm that the V2 engines still rev up to the 7K RPM, please?
Old Jul 7, 2008 | 06:56 PM
  #3243
ZeeForce's Avatar
ZeeForce
Joe,(camaros) got your pm, thanks I updated the list with your stats. Good luck!
Originally Posted by luvZcar
ok guys so I got my oil change today after 3100 miles my car was only 1/2 qt low things are looking good
Looks good, pm with your stats and I will update the list.
  #3244
ZeeForce's Avatar
ZeeForce
As I mentioned awhile back, if anyone wants their stats on the list, then send me a personal message (pm). Take a look at the first page for details.
Old Jul 7, 2008 | 09:17 PM
  #3245
Nismo1182's Avatar
Nismo1182
Mine still revs right up to the 7200 rpm cut off
Old Jul 7, 2008 | 11:44 PM
  #3246
jason350z's Avatar
jason350z
today i got my sencond v2. those of you that have had success can you guys give me some tips on how i should break in the engine. i have about 50miles on the new engine. i am going according to the owners manual as i did before. stay under 4k rpm. accelerate slowly. what else should i do?
it says not to drive at constant speed for a long time. what is consider a long time?
thanks
Old Jul 8, 2008 | 07:40 AM
  #3247
hbenet's Avatar
hbenet
Thank you ^! Wonder if mgnchakar got screwed with a non-Revup engine?
Old Jul 8, 2008 | 10:09 AM
  #3248
Nismo1182's Avatar
Nismo1182
The engine doesnt set the rev/fuel cut off the ecu does. I wonder if they reflashed his ecu with an older program or something?
thanks
I followed the book and I broke mine in to 1000 miles and changed the oil then.
I did some highway traveling while I broke it in too but I varied my speed between 60mph - 90mph about every 30 minutes or so for my 2 hour trip going and another 2 hours coming back.
Old Jul 8, 2008 | 12:03 PM
  #3249
luvZcar's Avatar
luvZcar
will do
Old Jul 8, 2008 | 01:25 PM
  #3250
06CPV35's Avatar
06CPV35
Yup...sounds about what I did when on a recent loong trip ~400mi there, ~150 city, then ~400 back varying every 20-30min on highway.
thanks
Think what Nissan trying to say is, don't stay at same rpm for hours on a trip. G/L with your second V2. I'd change oil now. Mine at 75mi had lots of metals in it + milky assembly lubes when drain first started. Then change couple more times till the 3750mi mark, but that's me.
Old Jul 8, 2008 | 07:47 PM
  #3251
ZeeForce's Avatar
ZeeForce
^^ +1 on the break-in and oil changes.
Get full throttle accels heading up hill and not at high RPM or loading. Back off when you hit 45 -60 and lift off. This seats and expands the rings and
cylinders. Perform this 5-6 times.
Get a used oil analysis (about 60.00) by dyson labs. He will work with you on the tune and engine components seating propoerly. This is as opposed to BlackStone which just gives you raw data to interpret.
gl
Old Jul 8, 2008 | 11:32 PM
  #3252
BC350Z's Avatar
BC350Z
sorry if this is a noob question
what if I bring an 06 from US into Canada, is the engine-swap-warranty still valid?
Old Jul 10, 2008 | 12:13 PM
  #3253
rickosae's Avatar
rickosae
Default Oil Consumption Club
Add me to the club. I'm new to this forum but have 25K mi on a 2005 Anniversary Edition MT. I get my first OC test Sat. morning, already 10+mm at 1200mi. According to the TSB I fail. It sounds like I have a good plan to keep my occasionally shady dealer honest. I will drop the car off friday night, find a level spot, lock it. Come back first thing & ask for my OC and insist on being there with them. Then get it in writing what they will do. I already have photographed 3 readings at 10mm at 1100mi + the odometer. I will do it again Friday morning when the car is cold at about 1350mi, it will most likely be 11mm or more. Sound like a good plan? Saturday is the big day .
Old Jul 10, 2008 | 09:37 PM
  #3254
ZeeForce's Avatar
ZeeForce
^ good plan.
Old Jul 11, 2008 | 10:34 AM
  #3255
SCARECROW BEATS's Avatar
SCARECROW BEATS
FIND A BETTER DEALER...
Old Jul 11, 2008 | 10:36 AM
  #3256
SCARECROW BEATS
gl
IM IN THE PROCESS OF BREAKING IN AS WELL, IN THE MANUAL IT SAYS DO NOT GO FULL THROTTLE...
YOU SUGGEST OTHERWISE?
SO ACCELL SLOWLY TO FULL THROTTLE, BACK OFF AT 40-60 MPH? AND DO THIS 5 OR 6 TIME?
Old Jul 11, 2008 | 01:13 PM
  #3257
RULE-1's Avatar
RULE-1
Default BLK 06' 21,000 miles
Just got my car back from Sutherland Nissan in Georgia with a fresh Motor! The most painless thing I have ever done. They where Great! I had them do the oil change, then I brought it back in 2,500 miles later and they confirmed it needed a new motor. I never said anything about wanting or needing a motor. 2 weeks later they called me to bring the car in, and they gave me a 08' Pathfinder rental (no cost to me). Thanks to Great Forums like this to do all the hard work for me.
Old Jul 11, 2008 | 01:18 PM
  #3258
SCARECROW BEATS
'08 PATHFINDER??? I HAD A DAMN SENTRA... NO FAIR.
SO ON CLOSER INSPECTION OF MY CAR AFTER HAVING THE NEW MOTOR PUT IN, I NOTICE A DING IN MY PASSENGER DOOR, MY EXHAUST IS AS CROOKED AS A GAY PIRATE, AND THEY DIDNT EVEN WASH MY CAR... ITS COVERED IN GREASE...
MAYBE I SHOULD READ MY PREVIOUS POST, 3 ABOVE...
DAMN IT.
Old Jul 11, 2008 | 02:32 PM
  #3259
cheshirecat79
Them not washing the car was their apology for the dent.
They figured they had already damaged your car enough.
Old Jul 11, 2008 | 03:31 PM
  #3260
SCARECROW BEATS
i know huh...
