RevUp Oil Consumption TSB and discussion
Old Mar 20, 2009 | 12:46 PM
  #3981
rich2342's Avatar
rich2342
What's up Guys,
I've got an 05 Altima se with oil consumption issues and have gotten the brush off already from the dealership and it's under extended warranty up to 100k. Is this a know issue for other models as well?
On a side note, im looking for a Z as a summer car. Is it advisable to stay clear of the 05/06 revvup? If I purchase from a nondealer would nissan still replace the engine pending the issue is there?
Old Mar 20, 2009 | 03:20 PM
  #3982
antennahead's Avatar
antennahead
Originally Posted by 4SHIZZIL
sounds like you need to save that money to offset the difference in being upside down on your car when you trade it in on a pre 2005 G35 or pre 2006 (Non_Rev) Z....then add boost. After one motor I was completely upset and frurious. I wrote Infiniti and told them that this was totally unacceptable for a 40K sports coupe. I lucked out with a handbuilt VQ from Japan that doesnt burn any oil, even while SuperCharged.
If I were in your boat, Id buy an older car and play with it...newer cars are so much more expensive especially when you consider the payments...
I wount buy a 370 or a G37 because you can play with it. If you leave the car stock and only want to add wheels and stereo, then cool. But if you want exhaust intake boost ect....id go with an older platform.
good luck and sorry for you frustration, I have been there..sadly all of us on this forum have been there too!
Your suggestion is something to consider. It's not being upside down that was my frustration, it was the offer on my car versus full retail on the 370 that ticked me off, as well as their attitude...... $800 less than wholesale on my car and nothing off sticker on the 370..... they can keep it and continue to let their floor plan eat them up
John
Old Mar 20, 2009 | 07:37 PM
  #3983
06CPV35's Avatar
06CPV35
Originally Posted by widesti
at the dealership as i am typing and the results of my consumption test is as it reads:
"measured oil at 4MM below full at 1066 miles driven. within range of normal oil usage per NTD"
so is that okay?
Look at TSB on first page. Haven't memorize the OC chart as far as 'ok' or 'no good' /mm's
Old Mar 20, 2009 | 07:42 PM
  #3984
06CPV35's Avatar
06CPV35
Originally Posted by rich2342
What's up Guys,
If it has factory warranty left, warranty follows the car regardless on how many owners.
Old Mar 20, 2009 | 10:55 PM
  #3985
ZeeForce's Avatar
ZeeForce
Originally Posted by antennahead
Dealer wouldn't "deal" on a new 370, and offered me nothing for my car in trade, as well as refusing to budge on retail, so ........... I am deciding just how bad this issue is and can I live with it. Last oil change on the V2, number 4, was the worst and the first that exceeded the TSB (used in excess of one quart). This oil change, with about 2400 miles into it, is about 2/3 to 3/4 quart, so it seems I am back to right at 1 quart between oil changes. What are your opinions. Do you think I will have longevity with this engine and continue to use in this range? Maybe settle down some and even consume less? Totally screw up and start consuming more? History here shows only 1 out of 5 oil changes exceeding a quart. I have about 20,000 miles on the new engine now. I believe Zeeforce stated his analysis showed he was still breaking in at 20,000. I need new tires soon and would like to put aftermarket wheels on the car, as well as upgrade the stereo. I hate to spend the bucks only to have the thing get worse on me. If the consumption stayed at about 1 quart between changes, I think I could live with that.
John
Give the purchase of the 370Z some more time, the economy is just starting to get a boost and dealers are selling off there 370Z’ to other dealers because they cannot sell them. My dealer has been gobbling them up from other dealers. Also try some other dealers to see if its is a pattern with no-budging on price or if it’s the dealer. Not to rub salt on anything, but I got my 370Z (Touring Sport minus Navie) for 37,300, that was 5k below dealer asking price. Then again we were buying two 370Z’s at the same time, and I had bought the previous two 350Z’s from same dealership.
To keep or to boot the 350Z?
I would go for the buy back, get the attorney, you will probably get more with a buy back than a trade-in or private sale.
If you want to keep it to see if it’s going to improve, then try this:
1) Switch to Pennzoil Platinum 5w-30
2)Use Amsoil’s oil filter.
3)Clean the air filter or better yet replace it, stay with a paper air filter. If using stock air box, then best bet is Amsoil’s drop in PAPER air filter.
4)Check for any air leaks in the intake system, from the air box to the throttle body.
5)Have you performed the WOT procedure yet? If not search this thread for my post on it (it was not that long ago that I posted it).
6)Use Shell VPower gasoline
7)The last one will cost you (you can only get this from a used oil analysis (UOA) with Terry Dyson) sorry.
Old Mar 22, 2009 | 09:29 AM
  #3986
06CPV35's Avatar
06CPV35
^ he's not interested in #7 and hasn't for years.
Too much hassel....
Old Mar 23, 2009 | 04:09 AM
  #3987
antennahead
Too much hassel....
No offense guys, Dyson does great work. I am just swamped right now, work wise, and we shouldn't have to go through all this if Nissan had built a reliable engine here. But I appreciate all the support and suggestions, thanks!
John
Old Mar 27, 2009 | 09:54 AM
  #3988
Chaser720's Avatar
Chaser720
Lemoned Z
First thoughts on the V2 in my car... SLOW
Its a good deal slower than my first engine. I had a stock clutch put it too (replaced a JWT) and that sucks too. I really cant stand to drive my car now.
Old Mar 27, 2009 | 10:28 AM
  #3989
Nismospeed4life's Avatar
Nismospeed4life
Sorry to hear that Chaser... That sucks !
Old Mar 31, 2009 | 03:21 PM
  #3990
antennahead
Well fellas, it's been great getting to know all of you, but it's adios for me from this thread...... I am now the proud owner of a 2009 370Z, Platinum Graphite Base with sport package!
John
Old Mar 31, 2009 | 03:37 PM
  #3991
Nismospeed4life
John
Congratulations....
Old Mar 31, 2009 | 03:43 PM
  #3992
antennahead
Originally Posted by Nismospeed4life
Congratulations....
You're welcome!
John
Old Mar 31, 2009 | 08:53 PM
  #3993
06CPV35's Avatar
06CPV35
^ Great color. Know someone with the same.
Congrats and enjoy...
Old Mar 31, 2009 | 09:04 PM
  #3994
photo2u's Avatar
photo2u
Default oc test follow up
Follow up from my last post,
I am asking for some help. I took my 06 with 12k Miles for my first oc test. The car logged 915 miles for the test. According to dealer’s service record, THE OIL WAS 1.5 QUARTS LOW-and approximately 6MM on the stick. The dealer found the oil within the acceptable ranges. The oil was filled up and I was told to bring back in 1000 miles.
My question is simple. Is 6MM in the oil dip stick equivalent to 1.5 quarts? Is this within the “no good range?
Please advice,
George from Pasadena
Old Apr 1, 2009 | 05:31 AM
  #3995
thekinn's Avatar
thekinn
I am asking for some help. I took 06 with 12k Miles for my first oc test. The car logged 915 miles for the test. According to dealer’s service record, THE OIL WAS 1.5 QUARTS LOW-and approximately 6MM on the stick. The dealer found the oil within the acceptable ranges. The oil was filled up and I was told to bring back in 1000 miles.
Please advice,
Page 1 of this thread. 1st attachment is a diagram. Open it - compare to your results.
Old Apr 1, 2009 | 06:08 AM
  #3996
06CPV35's Avatar
06CPV35
Please advice,
Sounds like they forgot a 3 in front of that 6mm.
1.5qts = 36mm.
6mm only = 1/4qt.
Old Apr 1, 2009 | 06:54 AM
  #3997
photo2u's Avatar
photo2u
Yes, I did review and print the attachment. I just wanted to review all the info available. The service tech that is working with me is a very well respected tech in this forum. I just want to make sure I review all of my info before I contact the service manager.
George from Pasadena,
Old Apr 1, 2009 | 08:03 AM
  #3998
06CPV35's Avatar
06CPV35
And he couldn't tell you 6mm does not = 1.5 quarts
G/L with those folks...
Old Apr 1, 2009 | 08:46 AM
  #3999
photo2u's Avatar
photo2u
Left message with service manager to please contact me to explain how they came up with their numbers.
In the service invoice they point out the 1.5 qts. However, they do not make any notes on the MM measurements.
I looking forward as what the manager has to say about the test.
Old Apr 1, 2009 | 09:32 PM
  #4000
photo2u's Avatar
photo2u
I do not what to say about West Covina Nissan. The service department manager did not get back to me today. I do not why? I asked nicely, that I had some questions regarding the oc test!
I will stop by the dealer to talk to him since he did not have the time to returned my phone calls.
