RevUp Oil Consumption TSB and discussion
Old Nov 2, 2007 | 08:00 PM
  #1861
Bevo's Avatar
Bevo
Originally Posted by CRXtoZ
This is what I have on the receipt:
2. Internal LOF ( what does it mean?)
LOF simply means lube, oil, filter.
Old Nov 2, 2007 | 08:01 PM
  #1862
Bevo's Avatar
Bevo
Originally Posted by luvZcar
If you look in the owners manual it states that our cars take 5qts of oil and that it should read at the half way between the H and L mark on the dip stick(page 8-10)and that is normal, but it is very true that it does fill(at the H)with about 5 1/2qts I believe from my experiences, with the oil 5qts filled right at the half way point and it still takes almost another1/2 to 3/4 qt to fill (to the H ) its very possible that your dealer just filled it with the recomended 5 qts and that it shows only half way on the dip stick. if I was you fill it to the H and watch it as we've all done in the past then see if it eating oil and let us know. I hope not that would look very bad for the fixed motor
That's weird, whenever i do my oil change, i pour in 5 qts and it's always at H mark.
Old Nov 2, 2007 | 09:11 PM
  #1863
antennahead's Avatar
antennahead
Not to be redundant, but my mechanic, who has done quite a few swaps, said a brand new engine will take about 5 1/2 to fill all the nooks and crannies in the new engine.
Old Nov 2, 2007 | 09:18 PM
  #1864
creationv2's Avatar
creationv2
+1
Old Nov 3, 2007 | 03:37 AM
  #1865
luvZcar's Avatar
luvZcar
your not being redundant its very true and bevo if your not changeing out the oil filter every time then it will take a little less to fill the oil (4 5/8) and its true that the oil in these cars for some reason seems to take awhile to drain totaly out so you might be getting some old oil sticking arround
Old Nov 3, 2007 | 07:55 PM
  #1866
antennahead
Having my oil changed Monday. Had it changed at 200 miles on the V2 to avoid any metal shavings from break-in. Dealer usually gets me in and out just before lunch, but was busy last week and asked me to come in Monday, so I am at 3850 miles since the change at 200 miles, as of today.
Checked the oil level today, and I am just over a 1/3 of a quart above "L" on the dip stick. This means I have used just under 2/3 of a quart in 3850 miles ........... remember, this is break-in as well. This is VERY encouraging. The engine runs great and gets better and smoother every day. If the next oil change at around 7500 miles is the same or better, I will consider this a winner ....... a V2 success!!! Just wanted to share the update, so you guys can update that spreadsheet you're keeping "smiles"
John
ps: I drive this car the way it was meant to be driven, don't abuse her, but don't baby her either .... spirited driving.
Old Nov 4, 2007 | 03:15 AM
  #1867
MoJ's Avatar
MoJ
Manufactured 02/06
22k miles
Due for an oil change and the level is 1/3 below full.
This is normal/to be expected for a properly functioning engine - correct?
Old Nov 4, 2007 | 02:29 PM
  #1868
ZeeForce's Avatar
ZeeForce
Default Hi all, I have been off line for the last week, out of state for my job.
Originally Posted by Mid117
Updates on my V1 motor replacement:
after 500-600 miles, oil level appears good....but I'll be watching it like a hawk
Thanks for the update. Any other info you can add for the stats spreadsheet would be appreciated.
Engine install date: ???
Oil type/brand/weight: ???
Hey guys, I just broke in my new V1, what oil you guys I should throw in?
Mobil 1 0w - 40 has been very successful with rblover69.
Others include:
Amsoil 0w - 30
Penzoil Platinum 10w - 30
Schaeffer’s 5w -30
Castrol GTX 5w – 30
Castrol Syntec 0w – 30 European Formula
Used Oil Analysis thread:
https://my350z.com/forum/engine-and-drivetrain/258663-vq-oil-analysis-and-info.html
Originally Posted by TuckandTwist
Just picked up the Z with the new engine. My invoice shows two line items on the invoice for the engine part number:
p/n AA20AA Replace Long Engine Assy
p/n 01N/10102-CD7M1 Engine, Bare
Can anyone tell me which version engine I received from this info?
Congrats, I will add to the list the first Non Rev Up replacement engine. It will be interesting to see the stats over time.
+1
+1
Will update the list and post up shortly.
Old Nov 4, 2007 | 03:55 PM
  #1869
4SHIZZIL's Avatar
4SHIZZIL
1) Dbasal - maybe not fixed. (no new update as of 10/12/07)
2) Theatrix - 3500 mi ….still NOT burning oil
3) RBlover - Success - Done w/Break-in. 4k mi…No OC when running Mobil 1 0w-40 synth w/synth oil filter.
4) 4Shizzil - Success 2k on synth and not a drop, dyno’d at 265-275
5) Zmaximus - still consuming (no new update as of 10/12/07)
6) Antennahead - 3k mi (changed oil at 200 mi) – so far so good - still pending
7) Creationv2 - dont know yet...only 100 miles
8) Hexxum001 - G35 with V2 motor - so far so good (no new update as of 10/12/07)
9) ZMedic16 - Still Pending (no new update as of 10/12/07)
10) ZLOC06 – 1400 mi and some OC - but still pending. (no new update as of 10/12/07)
11) ZPHILE - 45mi on V2 - still pending
12) luvZcar -5000 miles and still consuming ( new v1 under oil consumption test )
13) ZeeForce - 800 miles so far so good - pending break-in (oil changed at 500 miles with 5w-30 Castrol GTX, still full on dipstick)
14) jkim1978 - 0.5 qt per 1k mi – still pending (no new update as of 10/12/07)
15) pooch15 - 950 mi on V2 - Everything looks good so far.
16) neverbonestock – still pending
17) doublins – 1k mi - still pending
18) joe blow xbox – replaced with V1 – still pending
19) Mid117 – replaced with V1 – ***Update: 500-600 miles on new motor, checked oil, so far so good***
20) 9kFever – replaced with V1 – still pending
21) king67rsss – 20 mi – still pending
22) ROGERD – V1 longblock installed - consuming 2 qt per 3k mi
^ Hey guys, is the info current and correct?
If not, please update and repost this list.Thank
Mine has not burned a drop and I have been to the track a few times, autoXing and I just flat out drive like a bat... That dyno was with HF CATs, Stillen Y, MotorD 5/16, and Injen 3inch to 2.5 intake. Good luck all hand with it...I still have mixed emotions about my 38K paper weight..but then, there are other days like this.... click here....that make it all better.
Old Nov 4, 2007 | 04:06 PM
  #1870
4SHIZZIL's Avatar
4SHIZZIL
I ran the regular OEM stuff for the break in...then I went to Pensoil Platinum based off the Oil Analysis Thread found....
https://my350z.com/forum/showthread.php?t=258663
FYI: after 500 miles not 5000 like they recommend....I beat the crap out of my car for maximum piston ring seatage!
My two cents!
Old Nov 4, 2007 | 04:40 PM
  #1871
ZeeForce's Avatar
ZeeForce
Default V2 & V1 Installed Stats
Here is the latest stat's
It would make it easier for me to collect the data and update the spreadsheet, if the following format is used when posting your stats.
Thanks in advance
If you are new to the stat list, please provide the part # of your engine to verify if your engine is a V2 or V1.
Template:
Status:
So Far So Good – Still Pending
Some OC – Still Pending
Still Pending
Still Consuming
Success
OC: quarts per 1k miles: (please convert to 1k miles)
Engine Install Date:
Mileage on Engine: (new installed engine, not total mileage on vehicle)
Mileage on current oil change interval of 3750 – 4000:
Oil Type/Brand/Weight:
Old Nov 4, 2007 | 05:58 PM
  #1872
Mid117's Avatar
Mid117
Others include:
Amsoil 0w - 30
Schaeffer’s 5w -30
Castrol GTX 5w – 30
Cool, thanks for the informative response...Dealer did not say what kind of oil they used(probably the cheap stuff), but the new motor was swapped on October 12.
I did not break it in easy....I'm gonna get an oil change soon.
Old Nov 4, 2007 | 06:34 PM
  #1873
TuckandTwist's Avatar
TuckandTwist
Originally Posted by 4SHIZZIL
... I beat the crap out of my car for maximum piston ring seatage ...
I break in all my engines using Motoman's methods. Believe in it. Your engines will thank you.
Old Nov 5, 2007 | 07:11 AM
  #1874
dbasal's Avatar
dbasal
Thanks in advance
Template:
Status:
Still Pending
Still Consuming
Success
Attachment 166936
Just updating mileage, everything else is still the same. 11,000 on the v2.
I'm currently getting everything officially documented and then will decided what my next move will be.
Old Nov 5, 2007 | 11:52 AM
  #1875
BabyZiLLa's Avatar
BabyZiLLa
Well another one from Canada.
Dropped my car at Sherwood Nissan, Alberta, Canada few weeks back. Got the call today Nissan had agreed to replace the engine.
I was told there was a serious shortage for these new long blocks. Fortunately for me its winter so the cars asleep anyways, but Im told 3-4 months.
They asked me if it was parked for winter. I made the mistake of saying Yes. They said there giving the long blocks to anyone driving all year currently due to the shortage. So I have to wait.
Guess i'll post back in a few months when i get my engine.
Old Nov 5, 2007 | 02:22 PM
  #1876
ZeeForce's Avatar
ZeeForce
Thanks for the update, you have the most miles on the V2 and the results are encouraging. 0.3 qt per 1k mi (less than 1/3 qt) which calculates out to an average of 1qt 1/8 per oil change of 3750 mi. Keep us posted on your next move.
Guys,
I want to take a moment to recognize a couple guys that have been very instrumental in making this thread a success from the start. We all should take a moment and reflect back to say a year ago when everyone had no place to go for answers on the oil consumption issue, everyday new and different tales were popping up from the dealers and NNA, there was kaos, disbelief, confusion, frustration, anger, disappointment, stress, marriages were torn apart, (owner and car) brother against brother, those were the days. These guys put everything into perspective so today their time here has given the rest of us some ground work to base our case against NNA and the dealers.
dbasal and bofa are the godfathers of this topic. Their help, support and advice have been truly valuable for all of us in dealing with NNA and our dealers. Without their experiences dealing with NNA and sharing it with the community, this topic discussion would be nothing less than a be-chin thread. I would have to say this thread has been and still is the best thread on this site where everyone is polite and helpful to all. No thanks to dbasal and bofa for setting the tone.
A real asset to this community!
Thanks
-Curtis
Old Nov 5, 2007 | 02:26 PM
  #1877
ZeeForce's Avatar
ZeeForce
Congrats, the wait will be worth it. Keep us posted.
Old Nov 5, 2007 | 03:26 PM
  #1878
hieu's Avatar
hieu
hey guys. I got a new engine at about 8 K and now at 15 K this one is buring too. I am on the consumption test again at West Covina Nissan. I'll fill you guys in on what happens
Old Nov 5, 2007 | 03:53 PM
  #1879
luvZcar's Avatar
luvZcar
Zeeforce good to see you back ,how was new mexico?
Old Nov 5, 2007 | 03:55 PM
  #1880
luvZcar's Avatar
luvZcar
sorry to hear that as its the same story for me, my motor replaced at 6.5 k and now at just over 13k I'm waiting for a new motor AGAIN hope all goes good for you...keep us posted
