Place 2 order bearings?
Old Dec 6, 2006 | 11:38 AM
AAB350z's Avatar
AAB350z
Default Place 2 order bearings?
I'm about to have quaife lsd installed. Does anyone know a
web site where you can order the rear end bearings? Thanks.
Old Dec 6, 2006 | 01:47 PM
Robert@Z1motor's Avatar
Robert@Z1motor
Z1 Motorsports
Default Rear Diff Bearings
They are a Koyo Bearing and have the part # stamped on them. My supplier could not find them by the part # to buy them direct from Koyo. I had to order them from Nissan. Let me know if you need me to get some for you. I think they were around $60-$70 each.
Old Dec 6, 2006 | 01:55 PM
Eazzy's Avatar
Eazzy
If u have the brg out, any brg house will be able to get them for u or if u can get that Toyo # ----Miami would have one for sure as would Orlando, Maybe even Ft Meyers-----With the Phosphate Mines and Orange Groves in Fla, there are a few places
Toyo is a god brg. as is *** or others if u have to cross reference
Edit----JEEZ. Got starred out,,, F.A.G. ---Thats a Brand not a reference to gay people ----Not that theres anything wrong with that ----HA !!!
Old Dec 6, 2006 | 04:53 PM
Super Avan Z33's Avatar
Super Avan Z33
What is the different between the one that we normally can get it from the nissan dealership and the koyo bearing?
Old Dec 6, 2006 | 05:01 PM
Eazzy's Avatar
Eazzy
Even if Nissan dosnt use Koto ----NOTHING. Have to relize that when a company makes a machine ,weather it be a car or a Conveyer system or a Shop Vac, it uses existing Brgs that are standardized either Metric or SAE and build around that brg. Yrs ago I used to buy my Harley Motor Brgs at the bearing House. Hella Cheaper!!!
Goes for Seals also
Old Dec 7, 2006 | 11:46 AM
AAB350z's Avatar
AAB350z
Thanks for all the helpful info. Good stuff.
Old Dec 1, 2008 | 09:02 PM
Frequency 3.5.0's Avatar
Frequency 3.5.0
sorry to revive this thread but is it normal when the throwout bearing has "plays" (space to move around) as you can see in the pic the ring inside can move around and cause it uneven... this is a koyo throwout bearing...
is it normal???
Old Dec 2, 2008 | 08:08 AM
Eazzy's Avatar
Eazzy
A throwout brg has substantial play due to the constant alignment deviations it needs to overcome. The important thing is that it rotates smoothly with a little drag and no rough spots when you have it in your hand
Old Dec 3, 2008 | 06:06 AM
Frequency 3.5.0
yea, it rotates smooth as silk. thanks for the help!
Old Dec 3, 2008 | 07:03 AM
Eazzy's Avatar
Eazzy
But ----If you have it out, its always best to just replace it no matter what -----Point is.....if your doing a clutch job, a seemingly good throw out will fail before the clutch will. I dont know your situation, but food for thought
Old Dec 3, 2008 | 07:05 AM
Eazzy's Avatar
Eazzy
Although that looks like a new one if Im not mistaken
Old Dec 3, 2008 | 04:22 PM
Frequency 3.5.0
yes, it's new, came with the ACT kit... so how long do you think a t.o. bearing would last? under normal driving that is..
Old Dec 3, 2008 | 05:02 PM
Eazzy's Avatar
Eazzy
Too many variables. Heat, Shift habits, How well the bearing was packed from the manufacturer, Pressure plate force.
But as a rule a quality brg properly installed will last almost the life of the clutch and when it fails----just do a complete clutch rebuild.
Never just replace the TO.......Your already there, so do a complete.
Old Dec 4, 2008 | 09:24 PM
Frequency 3.5.0
yep, thanks
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
