Greddy oil pan and GT Spec lower front brace?
Guys, I have the GT Spec lower braces, and the front one sits right under the oil pan... Any idea if the Greddy pan will clear the brace? I know some of the bigger pans wont...
heres what it looks like now:
well it might rub if you have 600+hp and the engine moves really hard when you rev
an alternative would be to get solid motor mounts and not use the bar because the engine would become a huge solid strut bar
The APS and all other oil pans and JWT spacer will not clear the GT spec bar
Think about it man, thats a given. If it clears by mm's than it wont clear with a spacer. The motor mounts are a diffrent storry as well. Since they lower the engine they would be a no go as well. I cant put mine in because of it so I either sell the brace or sell the mounts. But definately cant have both.
EDIT: I'll let you know about the whole 600+hp thing and rubbing after my engine break in, if you want first hand experience.
and using the JWT spacer, I was meaning using that with the stock oil pan...
