Need help with Limited Slip Symptoms - Car jerking under load differential
Old Jan 4, 2007 | 09:25 AM
Machupo's Avatar
Machupo
Default Need help with Limited Slip Symptoms - Car jerking under load differential
Hey all,
Recently had my Z's rear end redone (replaced the old Cusco RS 1.5 with a new model -- long story). At any rate, i've put about 500 miles on the car in the past three months or so and started noticing that the car would jerk left and right last week. When I press on the accelerator I pass a certain point (acceleration load) and the car's nose jerks to the right. I usually have to slightly move the steering wheel to the left to compensate (drive straight). When I let off the accelerator (after a certain point, again) the car's nose jerks to the left (I have to bring the steering wheel back to neutral to drive straight).
Now, this has been getting more pronounced over the past two days and I'm only going to drive the car one more trip (to my local tool / mechanic shop). Wanted an idea of a couple things I could look at for problems. I'm going to change the rear end fluid at the same time (putting royal purple in). I'll also re-tighten all the mounting bolts on the pumpkin to shop manual spec.
Any other ideas? Anyone else had this weird problem?
My car has spent most of the past three months on the highway (at least 75% of the highway time in excess of 200kph), so this is very disconcerting (scary / dangerous) at these speeds!!!
Any help / ideas would be greatly appreciated!
Thanks in advance,
-nick
Old Jan 4, 2007 | 09:36 AM
rocks's Avatar
rocks
You screwed up something in your suspension.
Old Jan 4, 2007 | 10:26 AM
daytona350z's Avatar
daytona350z
^like that helps any...
well, its possible when the mechanics worked on your car, they may have adjusted some alignment bolts to gain acces to the diff, which can cause your car to veer left or right.
but, i had the same type of problem you did and it was all traced back to tire pressure. since a diff works when one wheel spins at a different rate than the other, it will try "work/lock" to the slower tire's speed.
this happened to me after i had tires mounted. there was a difference in 10lbs from the left to right side tire pressure and this is what caused my car to do, exactly as you described: veered one way upon accel and a differnt way on the decel. so check that first, then go in for an alignment to check the specs to see if they would make your car pull either left or right. so make sure they are equal from side to side, then go in for an alignment.
btw, what happend to your first cusco diff?
Old Jan 4, 2007 | 10:39 AM
Machupo's Avatar
Machupo
lol, thanks for the response
would having the ECU see different tire pressures throw it off? The two tires are within 3psi of each other, but one of the TPS isn't "hooked-in" to the car - i.e. I need to plug the car into a consult and get it to recognize one sensor (reads accurate in one wheel and -- in another).
At any rate, had the back two wheels off a week ago to check the brakes (had been glazing them a bit on the autobahn -- long-range decels from 280k to ~120ish), so maybe that screwed up my alignment a bit?
Long story short -- was having issues with a 3.9fd install with my original cusco rs (making tons of squealing), after three re-installs, decided to scrap the fd and went back to 3.5fd -- had continued issues with the LSD, so ended up replacing it as well.
Suspension is 30k miles old (4 years)... wondering if it is time to start replacing parts (very happy with the stock stuff, but noticing that it bounces a lot on the autobahn now).
Thanks for your ideas -- i'll check them out in the AM and report back with updates.
Old Jan 4, 2007 | 10:45 AM
daytona350z
humm....how long has it been since you had it aligned? that could aso be something to check out. your suspension should be still ok, and since you've got a euro spec car, i'd assume its the 2004.5+ suspension we have over here ion the states. dunno if its worn out, possibly sind you do drive at a much faster speed over there. (i wish i could drive the autobahn!)
i dont think the reading would affect it so much, just make sure the tire pressures are equal. good luck!
Old Jan 4, 2007 | 10:55 AM
Machupo's Avatar
Machupo
it's a 2003 USDM car (i bought it in dec '02 when i still lived in the US -- military)
Lol, i can't remember the last time i had it aligned -- probably a good thing to go check out!!!
Old Jan 4, 2007 | 11:22 AM
rocks's Avatar
rocks
This happend on my porsche 928 before. I paid a guy to do the rear shocks after i did the front, compression coil springs without an impact wrench is horrible. He left 2 washers out that keep the coilover from sliding back and forth under the car. I picked it up and was like wtf did you do to my car. He said it just needed aligned so i took it over to my alignment guy and he told me he couldnt fix it. I took it back to him and made him fix it.
Old Jan 4, 2007 | 11:37 AM
Machupo's Avatar
Machupo
ok, that being said, i have a stock suspension with only 30k miles on it. The suspension has never been altered. This problem has been getting progressively worse over a couple days, which leads me to believe something is loosening or unwinding slowly as opposed to breaking. At any rate, i'll take these suggestions in stride and see what i can come up with tomorrow.
thanks,
-nick
Old Jan 4, 2007 | 11:45 AM
rocks's Avatar
rocks
Something is the suspension is moving improperly. Such as a bushing has been removed or something like that. Some kind of washer. Was the diff taken out of the car to do the gears and lsd?
Old Jan 4, 2007 | 12:00 PM
Machupo's Avatar
Machupo
I imagine so, have to call up the shop to make sure.
Regardless, I was not feeling this movement a week ago, nor for the first two months, so it's not something that would result from a missing part (I would've felt that from the get-go). Maybe something that has loosened. I'll add some suspension checks to my to-do list (looks like a couple books of shop manual are coming with me tomorrow)
thanks,
-nick
Old Jan 4, 2007 | 12:14 PM
rocks's Avatar
rocks
Maybe one of the diff bolts walked its way out if i were i would get under the car and see if it looks like anything is wrong.
Old Jan 4, 2007 | 07:49 PM
ouch1011's Avatar
ouch1011
I'd start with a good inspection and replacing the gear oil with one that has a limited-slip additive in it. Royal Purple should, but read to make sure. If it doesn't include a limited slip additive, you can buy an additive separately and put it in as well.
Old Jan 5, 2007 | 07:12 AM
Machupo's Avatar
Machupo
turns out the tire pressure stick i was using was defective, read between 33-36 no matter what i put it on -- luckily i had my autoX big dial pressure meter -- had 36psi in the left rear and 12 psi in the right rear. Evened them out and works like a charm. Now the question is how did the pressure get that low, so i'm going to watch it for a day or so and see if it drops.
Might go ahead and change the rear end fluid while i'm at it (this is the first fluid in there since the rebuild... 500 miles is a good break in, i think )
Old Jan 5, 2007 | 07:49 AM
daytona350z
glad u figured it out yeah, change the diff oil, its probably been working a lil more because of the difference in the tires.
btw, if your changing suspension and like the oem stuff, i would suggest the 2004.5+ suspension, or the euro spec. it'll give you a much better ride with less bounce.
Old Jan 5, 2007 | 08:59 AM
Machupo's Avatar
Machupo
awesome -- i'll have to see if I can snag a set -- thanks again!
Old Jan 5, 2007 | 10:42 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I was just about to tell you to check the tire pressure. With my stiff sidewalls, its impossible to tell if a tire is flat. I had a nail in one tire, and 5psi of tire pressure in the left rear....didnt notice a damn thing visually. But the car would pull to the side, as you described.
Old Jan 5, 2007 | 11:03 AM
daytona350z
no problem always glad to help
aarrgghh
May 1, 2022 11:04 AM
pslamp32
Feb 8, 2017 09:07 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
Mattg350z
Oct 2, 2015 06:51 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
