Going NA, and I need parts with the highest HP and TQ #'s
Old Jan 14, 2007 | 11:55 AM
filmnews's Avatar
filmnews
Default Going NA, and I need parts with the highest HP and TQ #'s
I currently have a non-rev-up 2005 Enthusiast 6sp. My current mods are JWT Clutch and lightweight flywheel. My goal is to get the highest HP and TQ numbers from the following categories.
Headers: Is it Alphaworks?
Exhaust: ?
Intake: JWT Pop-Charger? Injen CAI?
High Flow Cats: ?
Spacer: Motordyne 5/16, I am pretty sure on this one.
Light Weight Crank Pulley: ?
Cams: Down the road, but would like imput.
Tune: Utech?
Can you please help me with these categories?
Old Jan 14, 2007 | 12:01 PM
Shift_Z33's Avatar
Shift_Z33
If you want the most HP then it's gonna cost quite a bit more for quality parts.
Headers: Is it Alphaworks? (Crawford)
Exhaust: ? (I like Nismo, HKS, or Fast Intentions)
Intake: JWT Pop-Charger? Injen CAI? (JWT)
High Flow Cats: ? (Crawford, or just get test pipes)
Light Weight Crank Pulley: ? (I dont think these are worth the hp/$)
Cams: Down the road, but would like imput. (JWT, Nismo, or Tomei depending on how big you want to go)
Tune: Utech? (It's UTEC)
These are just my opinion and what I would do.
Old Jan 14, 2007 | 12:24 PM
filmnews's Avatar
filmnews
Where can you buy Crawford headers?
Old Jan 14, 2007 | 12:28 PM
Shift_Z33's Avatar
Shift_Z33
http://crawfordz.com, These are harder to install but most people show a little more power over ther others. I will probably be getting the DC or Strup just b/c of the easier install. I've also heard something about the Crawfords boiling clutch fluid but Im gonna let you go search around and see what you ultimately want for your car. There's tons of info out there.
Old Jan 14, 2007 | 12:34 PM
filmnews's Avatar
filmnews
The only thing I am worried about with headers, is RASP! Does anybody know if these Crawford headers or Alphaworks headers make the car sound RASPY?
Old Jan 14, 2007 | 12:40 PM
Kam350z's Avatar
Kam350z
If you want high horsepower don't go NA. It's as simple as that.
Old Jan 14, 2007 | 12:46 PM
filmnews's Avatar
filmnews
My goal is to have a NA setup that runs low 13's. (13.1-13.3)
Old Jan 14, 2007 | 01:04 PM
wooochang's Avatar
wooochang
good thread, im interested as well. subscribe
Old Jan 14, 2007 | 01:09 PM
FastZ33's Avatar
FastZ33
how much money do u have?
Old Jan 14, 2007 | 01:12 PM
filmnews's Avatar
filmnews
I am not going to buy everything at once, but I do plan having it all by the end of summer. I am willing to pay good money for parts.
Old Jan 14, 2007 | 01:13 PM
FastZ33's Avatar
FastZ33
Headers: crawford
Exhaust: hks ti
Intake: Injen CAI?
High Flow Cats: labree res tp
Light Weight Crank Pulley: UR underdrive pulley
Cams: jwt
Tune: Utech or techno square
drive train: 3.91 gears
nos-opitional hehe
cf hood, cf hatch with plixie glass, cf doors, and stripped out z with sparco light weight seats, and ull have a car that his mid 12............that r on 11in drag radials lol
Old Jan 14, 2007 | 01:47 PM
filmnews's Avatar
filmnews
I think that I will go with the Injen CAI, over the JWT. I am going to be showing this car, and they seem to have similar gains. I forgot about the gears, but that will probably be next winter.
Old Jan 14, 2007 | 01:51 PM
filmnews's Avatar
filmnews
Now, about the headers. I have read that the Crawford headers add 20HP with the plenum and their high flow cats. Then, I see that the Alphawork headers only add 21hp. http://www.nexusindustry.com/alpha_i...OVMTC=advanced
Does the Alphawork header dyno include other parts? Does the alphawork dyno sheet look off (Like they under estimated the stock run)?
Old Jan 14, 2007 | 01:58 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Light weight wheels, with DRs
JIC Ti Single Exhuast,
Crawford Headers and Stillen test pipes.
Motordyne spacer & JWT pop charger & clutch & Flywheel.
After that the numbers your seek just takes driving skill.
Old Jan 14, 2007 | 02:08 PM
350Zenophile's Avatar
350Zenophile
Don't forget lightweight clutch/flywheel combo.
Old Jan 14, 2007 | 02:16 PM
FastZ33's Avatar
FastZ33
Alphawork headers rnt all that grt honeslty
Old Jan 14, 2007 | 02:18 PM
FastZ33's Avatar
FastZ33
MI 35 has a point on the JIC single TI exh, saves u a lot of weight and it give pretty good gains but not sure if it s more or less then the hks ti, but the whole exh weights under 10lbs.............and saving weight is key in this game
Old Jan 14, 2007 | 02:34 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
100 lbs is est about .10 of a second off 1/4...
You can easily shead 100 lbs if all you want to do it drag, also Id remove the front sway and sound deadoning material, lightweight seats and dry carbon hatch with lexan window. Aftermarkets coilovers will also let you get outta the hole quicker.
Old Jan 14, 2007 | 03:26 PM
filmnews's Avatar
filmnews
I will be removing the subs and spare tire when I go to the track.
Old Jan 14, 2007 | 03:27 PM
filmnews's Avatar
filmnews
I just got this put on. JWT
