Dynoed my car (revup with cams)
Old Feb 4, 2007 | 08:15 AM
RBlover69's Avatar
RBlover69
im very curious also, i dynod stock at 251 dynojet std. And im also researching how much power can be made with the revup. With the wake of the HR us revups have to make a showing man. lol.jk What where ur results.
Old Feb 4, 2007 | 08:53 AM
chris'smax's Avatar
chris'smax
this is f%%%ing gay. Why post this $hit if you are going to share the numbers?
Old Feb 4, 2007 | 09:57 AM
Beta99's Avatar
Beta99
Old Feb 4, 2007 | 10:20 AM
bacalhau16's Avatar
bacalhau16
He will be sharing, patience, patience...
I guess you guys have never been subject to an antisipation shot at the bar.
Old Feb 4, 2007 | 10:26 AM
rocks's Avatar
rocks
Not posting because its worthless without scanning it. I dont have a scanner at home and my friends is broke, so i have to wait untill the morning when i go to work where i have a scanner.
Old Feb 4, 2007 | 10:57 AM
OhMyG35god's Avatar
OhMyG35god
just give us the numbers.. who cares if you have a scanner. nobody is going to take the numbers for fact anyway, the dyno was broken.
Old Feb 4, 2007 | 11:00 AM
Theatrix's Avatar
Theatrix
Professional
+1......................no point to this thread!
Old Feb 4, 2007 | 02:05 PM
RebelinRI's Avatar
RebelinRI
Old Feb 4, 2007 | 02:09 PM
TheProfessional's Avatar
TheProfessional
+3 waste of my time
Old Feb 4, 2007 | 02:15 PM
98sr20ve's Avatar
98sr20ve
Give him a break, He will post the dyno tommorow.
Old Feb 4, 2007 | 02:20 PM
RebelinRI's Avatar
RebelinRI
Arm? Neck? Leg?
Old Feb 4, 2007 | 02:33 PM
Barzten1's Avatar
Barzten1
Yeah I was there for some of the build phases. Motor started right up.
Old Feb 4, 2007 | 06:07 PM
rocks's Avatar
rocks
Bartzen was your car the silver Z in todds shop? If so i saw it when i took my car up there. The reason im not posting is the numbers arent that important but the power curves that the cams make, without the dyno sheet its worthless.
Old Feb 4, 2007 | 07:52 PM
Barzten1's Avatar
Barzten1
I'm not complaining. Patiently waiting for tomarrow. Yeah that was my Z with the carbon fiber hood.
Old Feb 4, 2007 | 08:08 PM
Jay'Z's Avatar
Jay'Z
FTLOG(for the love of god)........ EBAY headers???????????????????????????????????????????
Old Feb 4, 2007 | 08:15 PM
dkmesa350z's Avatar
dkmesa350z
Originally Posted by rocks
I wont be able to scan the dyno untill monday, so ill tell the numbers then. Its untuned on 86 octane, JWT S7 cams, 9.1 compression, ebay headers, test pipes, PIT exhaust, homemade shortram intake. I found a stock Z on a mustang dyno gets about 210-220 to the wheels ( According to Gruppe S ).
Since i cant scan it untill monday ill let you guys speculate at my dyno numbers with my super low compression.
210-220 is typical for non-HR...HR usually reads higher. Why are you running cheap gas?? Ebay headers FTL
Old Feb 4, 2007 | 08:16 PM
rocks's Avatar
rocks
Cheap gas is fine with low compression. Ebay headers also work fine, if you weld them . The cams were like 1100$ i think, and used the jwt valve train kit. Im trying to figure out if the jwt valve train is ok for 7500rpms, but searching does not give me that information.
Old Feb 4, 2007 | 08:17 PM
  #38
Sleeper01's Avatar
Sleeper01
Doesnt the car need 89 or high? if u use anything lower then 89 wont that F*ck up your engine
Old Feb 4, 2007 | 08:21 PM
  #39
Mid117's Avatar
Mid117
WTF? 86 octane in a Z? Sell your car immediatley
Old Feb 4, 2007 | 08:28 PM
  #40
rocks's Avatar
rocks
Its 9.1 compression. It runs rich. Do i have problem? No i do not have a problem using 86. If you did some research you would find out that you can even run 86 in a 10.3 Z because the factory ecu has a built in safeguard and a map for it to pull out timing and add fuel in. I used 86 octane in my porsche 928 and it was 9.3 compression for 5 years and it never had a problem.
Oh yea i used 86 in my altima at 10.2 compression for 3 years and it ran perfectly fine. Before i built the engine i used 90 octane.
