Mobil 1 Oil Users - Motor oil discussion thread
Old Aug 29, 2007 | 05:21 PM
  #281
03aeroZ's Avatar
03aeroZ
so two questions:
1) is the american 0w-30 castrol still a good synthetic?
2) has anyone done an analysis on the amsoil 0w-30? did it do as well as the castrol stuff?
Old Aug 30, 2007 | 10:25 AM
  #282
shushikiary's Avatar
shushikiary
Originally Posted by 03aeroZ
so two questions:
please reference this thread to answer your questions:
https://my350z.com/forum/engine-and-drivetrain/258663-vq-oil-analysis-and-info.html
Old Apr 23, 2008 | 06:47 PM
  #283
j.arnaldo's Avatar
j.arnaldo
Addictive additives?...Whoa...
Old Apr 23, 2008 | 08:40 PM
  #284
jonnylaw's Avatar
jonnylaw
$29.99 for 5 quarts of mobil1 0w40 and mobil1 filter at pepboys.
Old Apr 24, 2008 | 05:36 AM
  #285
Resolute's Avatar
Resolute
You had to bump THIS thread? LOL
Will
Old Apr 24, 2008 | 12:08 PM
  #286
jonnylaw's Avatar
jonnylaw
Will
Sorry Will, but since I have your attention, do you know if certain kinds of oil contribute/prevent blow-by than others, or is blow-by dictated more by humudity and driving style?
Old Apr 24, 2008 | 04:09 PM
  #287
Resolute's Avatar
Resolute
Blow-by is mostly a product of engine braking. If you have issues with blow-by from mechanical problems, such as improperly seated rings, then changing oils won't help much. Since most oil loss from blow-by occurs as vapor, getting an oil with higher NOACK scores might help. Usually, PAO or Ester base oils and higher weight oils will have higher NOACK scores. If you're using the M1 0W-40, then that's a good oil. M1 turbo diesel 5W-40 would be better, though.
Will
Old Apr 24, 2008 | 04:25 PM
  #288
jonnylaw's Avatar
jonnylaw
^^Ok thanks Will. Recently I noticed my ccan getting a little more oil/water vaper stuff than usual. Was using Motul 8100 before, but after reading through the UOA thread, I changed to Mobil1 0w40. I'll look into the turbo diesel, though, and a local shop has Amsoil, so I might try that too.
I haven't noticed any substantial oil consumption issues when checking oil levels b/w changes, however, but I will be looking to get a compression check, etc. before going F/I.
Old Aug 8, 2008 | 03:07 PM
  #289
TheOtherRob's Avatar
TheOtherRob
just changed to mobil 1 0-40 and my engine is starting to shake, rpms are very low, and shakes on the highway. WTF is wrong?
Old Aug 8, 2008 | 03:37 PM
  #290
rcdash's Avatar
rcdash
Hmmm... Did anything else change? I would double check the oil level after a night sitting.
Old Aug 8, 2008 | 09:46 PM
  #291
TheOtherRob
I made an update here.
https://my350z.com/forum/maintenance...il-change.html
I still have no clue as to why that happened. Hopefully someone can shed some light.
Old Aug 8, 2008 | 09:53 PM
  #292
nismo240r's Avatar
nismo240r
i've been using Mobil 1 5w-30 for the past 10,000km's and i love it. . .the G loves it as well, doesn't burn up a single drop of oil and it's still clean as the day it was dropped in. Just passed 60k km's on it and drove up to Yellowknife, N.W.T., drove back down and entered in 3 drift competitions . . .
I used Royal Purple before this (same weight) and it used up a little oil. . .
I'll be doing an oil sample/particle test this oil change and share the results. . .
Old Aug 10, 2008 | 06:36 AM
  #293
chavoush's Avatar
chavoush
For those interested, I also just changed over to M1 Euro 0W-40. Walmart sells this for a tad under 6 bucks, autozone sells it for a tad over. I've only found it in quart size.
Old Aug 10, 2008 | 11:33 AM
  #294
blackz123's Avatar
blackz123
500 miles on rp so far no problems very satisfied might try this gs next but most likely will stay with rp
Old Aug 12, 2008 | 05:50 AM
  #295
bswanny's Avatar
bswanny
What would you guys recommend for the extreme climate changes in Wisconsin weather (hot summer, cold winters)? Would 0-30W be okay? Thanks
Old Aug 12, 2008 | 06:03 AM
  #296
nismo240r's Avatar
nismo240r
5w-30 all year round. . .it's been driven in the heat and in -65 celcius. . .no problems yet . . .
Old Jun 30, 2010 | 01:03 PM
  #297
Patsfan83's Avatar
Patsfan83
You guys are going to kill me for bumping this but
I just switched from Castrol to Mobil 1 apparently it's called full synthetic but in the OP's post says it isn't, but the car runs really well on it, It feels alive but damn it was expensive as hell. $88!
Old Jul 1, 2010 | 07:57 AM
  #298
rich2342's Avatar
rich2342
Guys were swithching From Mobil 1 to Castrol, why the reverse?
Mobil 1 was shown to somewhat increase wear? Has it been reformulated?
Old Jul 1, 2010 | 11:05 AM
  #299
thescreensavers's Avatar
thescreensavers
Neither Syntec (exclude 0W-30) or M1 are synthetic they are highly refined oils.
But Syntec shows much better ware in UOA on the VQ engine then M1.
Old Jul 1, 2010 | 01:53 PM
  #300
whoisthis's Avatar
whoisthis
so to sum it up, Amsoil ATM 5w30, tso 5w30, Castrol 0w30 from Germany, 5w30 European formula, and pennzoil platinum 5w30 are good choices?
