Oil, 0w-30?
Old Mar 17, 2007 | 05:14 PM
Nero's Avatar
Nero
Default Oil, 0w-30?
whats the pros and cons of 0w-30, i live in a warm climate that rarely gets below 20 degrees and i read that 0w-30 gives the best hp and torque than 5w or 10w. whats the reall difference? which should i use? thanks also, how much longer does synthetic oil last vs normal oil?
Old Mar 17, 2007 | 05:28 PM
litlechina's Avatar
litlechina
curious as well
Old Mar 17, 2007 | 06:06 PM
MustGoFastR's Avatar
MustGoFastR
Check out this thread:
https://my350z.com/forum/engine-and-drivetrain/253651-mobil-1-oil-users-motor-oil-discussion-thread.html
Old Mar 17, 2007 | 08:46 PM
IP05G35's Avatar
IP05G35
Amsoil TSO 0w-30 is good stuff. The 0w just means it is thinner when cold and is better for your car at cold startup. Once the oil warms up it's the same weight as other 5w-30's.
Old Mar 18, 2007 | 07:29 PM
rcdash's Avatar
rcdash
Castrol Syntec 0W-30 (european version) is a true synthetic that appears to work well with the VQ and available at Autozone for a good price.
Old Mar 18, 2007 | 07:42 PM
IP05G35's Avatar
IP05G35
GC is a good oil but almost a 40 weight oil in thickness which will give you worse MPG and feel more sluggish compared to lighter weight oils.
Old Mar 18, 2007 | 07:51 PM
litlechina's Avatar
litlechina
so 0w30 is pretty much the same as 5w30, but 0w30 is better for cold starts? Why doesnt nissan just use 0w30 then?
Old Mar 18, 2007 | 08:31 PM
IP05G35's Avatar
IP05G35
5w-30 is easier to find, almost every oil company has a 5w-30 while 0w-30 is very rare. Some Audi's come with 0w-30 from the factory and that is the recommended viscosity.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
